Tractor Sizing Info for 86 horese JD 3120 Tractor
   / Info for 86 horese JD 3120 Tractor #1
ddoby
Kaufman, TX
John Deere 3120 & New Holland WM45
Does anyone have any info for the 69-71 86 horse JD 3120 tractors? I can't find much. Everything I find under 3120 is for the newer compact tractors.
   / Info for 86 horese JD 3120 Tractor #2
Check and see how similar this is to a 3130. IIRC the 3130 is 86hp too and should be very similar. Is yours a 6 cylinder?
What kind of information are you looking for?
   / Info for 86 horese JD 3120 Tractor #3
Most likely a Canadian or European version of the 3020. Put Model 3120 in the model search of JDparts and see what comes up.
   / Info for 86 horese JD 3120 Tractor #4
It is different from the 3020, more the size of a 4020 but not as good imo.
This 3120 he is inquiring about is a 6 cyl tractor with a 303 cu in engine which is about half way between the 3020 and 4020 engines.
I agree it is an European version with parts that are more difficult to locate in most cases.
2021 JOHN DEERE 648LB GRAPPLE SKIDDER (A52705)
2021 JOHN DEERE...
Utility Trailer (A52377)
Utility Trailer...
2019 JOHN DEERE Z960M ZERO TURN LAWN MOWER (A54756)
2019 JOHN DEERE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
