Inexpensive Tow Vehicle
/ Inexpensive Tow Vehicle #21
</font><font color="blue" class="small">( How old is that f250 super duty? and what is its gvwr? )</font> It's a 2002 with a gvwr of 8800. I can tow up to 12500 but only with a weight dist hitch.
/ Inexpensive Tow Vehicle #22
You need a full size pickup.
I have used an import SUV and they just don't cut it. The springs are just not cut out for any heavy loads. More than a couple hundred pounds of tongue weight and your lights will be shinning at the moon. The domestic SUVs are not much better unless you get an older one or one with a V8.
I now use a one ton single rear wheel dodge crew cab. This is my primary ride that I drive to work every day. I can get ~20 mpg on the highway due to the turbo diesel and legally pull 14.5K lb trailers.
To date the heaviest I have pulled was ~10K lbs. It would be possible to get a speeding ticket pulling this trailer up a steep hill.
You could forget you even had a 6k lb trailer behind this rig, and still park in a garage due to the short box.
Maybe over kill for you but a used 1/2 ton or even better 3/4 ton domestic truck would fill the bill nicely.
Diesel will cost you more but run about twice as long.
The only import that I have seen that could fill the bill is the nissan titan, but that means a new truck and probably $23K minimum.
Fred
/ Inexpensive Tow Vehicle #23
If you want something cheap as a tow vehicle a used cargo van is hard to beat. Something like an E350 can do a lot of towing and can be had very cheap... much cheaper than a pickup.
2001 CAT 725 6x6 Water Wagon (A62679)
2001 CAT 725 6x6...
2025 66in Swict Bucket Skid Steer Attachment (A64553)
2025 66in Swict...
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
Landhonor 65' Retractable Air Hose Reel (A66408)
Landhonor 65'...
2016 KENWORTH T800 TRI-AXLE (A65643)
2016 KENWORTH T800...
Mini Universal Root Rake (A65640)
Mini Universal...
