Industrial Tires on YM2002d?
   / Industrial Tires on YM2002d? #1
wildbitshomestead
Yanmar 2002D
Hi all, Trevor here, new to the forum. I have a YM002d that I purchased about a month ago. it came with ag tires on it, and now Im thinking about putting industrial or turf tires on it. I have 5 acres of sloped land, mostly wooded, and very quickly realized that I need something a bit more stable and some weight on the back (will fill rear tires with beet juice).
Have any of you put industrial tires on a YM2002d or similar yanmar? Thoughts, advice, suggestions welcome. Thanks
   / Industrial Tires on YM2002d? #2
Welcome to the forum. :welcome: Have you got your wheels in the wide stance?
   / Industrial Tires on YM2002d? #3
I also have a YM2002D. When I got mine about 7 years ago, it had worn out front tires on it and 1 worn out ricer tire on the rear and one fairly new AG tire on it. The ricer was replaced after a flat soon after I acquired it when I discovered a rather large chunk of tire gone with a piece cut in to fit. The fronts were also replaced. There was a bit of confusion regarding the front tires as 6.00-14 and 5.00-14 were both listed in different places for the front. After much research I went with the 6.00-14 tires.
Winston1 has for me been a great resource for information on the 2002D as he has one or at least had one.
I have not heard of many putting industrial tires on any model of YM series Yanmars. Hoye does have a turf tire option for the YM’s, but it requires replacement of wheels, combine tire and wheel purchase is quite an investment.
As for stability, do you have your tires with the ‘dish’ facing out or in? Facing out will give you a wider stance.
Feel free to ask questions either through the forum or message board.
   / Industrial Tires on YM2002d? #4
This is one of those bits of wisdom that I have gained from Winston1
   / Industrial Tires on YM2002d? #5
My Org. Bridgestone started to dry and crack at the lugs. Then I was repairing the tubes. My craftsman Garden tractor would tear up the Grass when wet also. Flat wide turf tire. I just learned to let the spots were it was extremely wet dry up and then cut it. The Org. rears I finally had to do something. After studying my options, It hit me what Steve at Spalding told me when I bought it asking about them. He told me to just reline them. Which I did in 2016. Not the first complaint. Here's what I used and only took the tire shop a couple minutes to install. Gempler 9DR7 8x24, 9x24, 8.25x20, 7.50x20 Tire Reliner
I'm all for saving $ "Which was A Lot" compared to replacement. :thumbsup:
   / Industrial Tires on YM2002d? #6
I would have lived to have been able to reline the rears, but there was a hole large enough for 1 fist to freely reach into the tire, fronts were just worn out, tractor was stuck in 4x4 when purchased. (That has been corrected). I looked for a photo of the rear tire, but have not located yet. My flat actually happened because the ‘patch’ moved and ripped the tube.
   / Industrial Tires on YM2002d? #7
They would still work is my bet !! The reline was thicker than the Org. Tire and looked to have Steel woven in it. 150.00$ total cost for both tires including the Tire shop. I'll never wear them out........... My setup!!!!
   / Industrial Tires on YM2002d? #8
I pulled the Packing list and seen were I noted the sale price. 9/16 2 ordered @ 127.18 and 35.00$ to install. Went and checked if they was still available which they are. The price sure went up. Imagine That. They Work!!!
9.5x24 Tire Guard for Rear Tractor Tire — Gempler's
Thanks for the advice all. I realized that Les Schwab tire shop will fill the tires with beet juice, so I think Im going to take it over there adn have them fill them up, and while Im at it, swap out the wheels for more stability (left to right, right to left). Will try that and see how it does before spending a chunk on new tires/rims. Would love to have a bit wider/lower stance at some point for the slope of my property, but spending 2k on turf tires is a bit much at the moment. Plus, if i want to drive it in muddy conditions, I'd probably have to put chains on the turf tires also. Had my garden tractor out spreading some wood chips in a muddy area the other day and slid all over the place with it, and those are turf tires.
Thanks Coy. I need to put the dish facing out, haven't done that yet. A wider stance is definitely needed. Think I'll have the guys at Les Schwab do that before they fill them with beet juice when I take it in.
2021 ARISING INDUSTRIES, INC 24 T/A ENCLOSED TRAILER (A52472)
2021 ARISING...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2006 HEIL MC407 (A52472)
2006 HEIL MC407...
2014 Ford F450 Altec Bucket Truck (A52377)
2014 Ford F450...
