Indicator Bulbs
/ Indicator Bulbs #1
jebb
Central Kentucky
Kioti DK35
I have a turn signal indicator bulb and a 4WD indicator bulb on the dash that have burnt out. Does anyone know the proper replacement bulb. I would like to purchase the replacement prior to taking the dash apart.
Thanks
/ Indicator Bulbs
I guess I should have said that I have a DK35
/ Indicator Bulbs #3
My dash illumination lamps are 3.4 watt wedge base. I know this as they are sitting at my compuerter desk. I would assume they used the same lamps throughout the dash but this lamp is off a LB1915
/ Indicator Bulbs #4
Along these same lines, I have a new ck 30 and some work and some do not. My parking brake both turn signals oil and igniter work. How many more are supposed to work in a gear model? Do I hav a 4x4 light? pto light? high range? low range? any other? Thanks, Mike
CASE INTERNATIONAL 230 - 35' TURBO TILL (A63291)
CASE INTERNATIONAL...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2011 KUBOTA KX121-3ST SUPER SERIES EXCAVATOR (A64279)
2011 KUBOTA...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
UNUSED WOLVERINE 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
