Independent Lift for MMM on 2305 w/ 260 BH
   / Independent Lift for MMM on 2305 w/ 260 BH #1
Phunge
Do I need it?
It's unlikely that I will want to run the MMM and BH at the same time. However, I'd like to be able to switch between the FEL/BH and MMM without having to install the arms on the 3PH.
Does anyone know if the arms on the 3PH are required for the mechanical lift?
   / Independent Lift for MMM on 2305 w/ 260 BH #2
Yes, One arm is required (The left one). In fact if you use the collection system you take off the right one and just use the left one.
It's just a little bracket that latches over the top of the base of the left 3pt arm. If you had a 3pt arm you could sacrifice you could cut it off to maybe 4-6" from the pivot point and that's all the mechanical lift needs. I'm sure that wouldn't interfere with BH but the lift arms for it might.
You could probably also custom fabricate something. I've thought of putting a simple mechanical lever (like most Garden tractors) so I can mechanically lift the deck from a lever and not require the 3pt hitch or the hydraulic lift.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
Lot of 2 Loader Tires (A51691)
Lot of 2 Loader...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A53472)
2014 Yale 3 stage...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
