Independent Lift for MMM on 2305 w/ 260 BH
   / Independent Lift for MMM on 2305 w/ 260 BH #1
Phunge
Do I need it?
It's unlikely that I will want to run the MMM and BH at the same time. However, I'd like to be able to switch between the FEL/BH and MMM without having to install the arms on the 3PH.
Does anyone know if the arms on the 3PH are required for the mechanical lift?
   / Independent Lift for MMM on 2305 w/ 260 BH #2
Yes, One arm is required (The left one). In fact if you use the collection system you take off the right one and just use the left one.
It's just a little bracket that latches over the top of the base of the left 3pt arm. If you had a 3pt arm you could sacrifice you could cut it off to maybe 4-6" from the pivot point and that's all the mechanical lift needs. I'm sure that wouldn't interfere with BH but the lift arms for it might.
You could probably also custom fabricate something. I've thought of putting a simple mechanical lever (like most Garden tractors) so I can mechanically lift the deck from a lever and not require the 3pt hitch or the hydraulic lift.
New Holland LX865 Skidsteer (A51573)
New Holland LX865...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
Hay Spear for Tractor (A51573)
Hay Spear for...
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
