derifarm
I just bought a DK45HST that I'm quite happy with! I want to make one change to my machine that I want to check first with all of you. I currently have AG tires on it and I'd like to get the space between the tires (inside span) to a little more than 46 inches (120 cm.) The specs in the manual show that I can turn the wheels out and with the AG tires should get to a little less than 45".
So, the question is: do you think it would be a problem if I were to put in a 3/4" spacer between each hub and wheel rim? Would this cause undue stress on any part of the tractor? Also, if any of you have an idea for a spacer, I'd love to hear it.
The purpose of this is so that I can straddle the bed I'm creating with my 46" Imants Spader. I'm going to try to create permanent sod tracks and only spade/till that space between.
-Justin
-Justin
