Increasing pond size
/ Increasing pond size #1
LeeL
Winter Springs, FL looking to retire in Lake Placi
Kubota B2650
The pond on our property, when originally dug by the previous owner, had a shallow end. When the water levels were low it was only a wet grass area.
Last week I got a loaner Cat excavator to dig out the shallow end and connect it to the main pond. The wife stayed busy moving a little of the dirt with the Kubota.
/ Increasing pond size #3
Now that's having to much fun. ;) :thumbsup:
/ Increasing pond size #4
pond spring fed or run off? (or maybe just water table related being in FL?)
/ Increasing pond size #6
needs some caiman or alligators. looks good. will you landscape the margin of pond? irrigation will be easy.
/ Increasing pond size #7
....Gator heavin right there.. lol
/ Increasing pond size #8
Nice job. Love seeing the wife out there working hard too!!!! Teamwork.
/ Increasing pond size #9
With a foot adz and a hand adz that pine log could be hewed into a good looking crocodile...!
/ Increasing pond size #12
20 years ago, my sister had that done to the pond behind her house,,
the one acre pond was doubled in size,,,
They had a guy with a dragline excavate it out,,,
the counterweight on the dragline was multiple pieces,, and weighed 90,000 pounds,, JUST the weight of the counterweight.
Well, one night, the operator did not back away from the pond far enough,, the earth gave away,, the dragline flipped on its side, into the pond,,,
Luckily, the dragline owner knew some recovery specialist from Norfolk VA,,
the guy drove up with a one ton truck full of cable, and pulleys,,
They buried a 2 foot diameter, 20 foot long hickory that was cut from the farm they were on,,
using that as a deadman, buried over 15 feet deep,, the farm's 4WD JD tractor was hooked to the cable,,
and the tractor went close to 1/8 of a mile, pulling the cable,,
IIRC, the cable was a 6 way lay,,, that farm tractor never spun,, it simply pulled the giant dragline out of the pond, and flipped it back on its tracks,,
So, the moral of the story is,,, DO NOT park the excavator on loose soil over night,,,, :eek:
2012 KENWORTH TROAXLE BODY  LOAD (A67714)
2012 KENWORTH...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
150 GALLON FUEL TANK (A68842)
150 GALLON FUEL...
CEDARAPIDS HEAVY DUTY ROCK SORTER (A66734)
CEDARAPIDS HEAVY...
2012 TREMCAR CRUDE OIL TRAILER (A67714)
2012 TREMCAR CRUDE...
2016 Dodge Charger Sedan (A66738)
2016 Dodge Charger...
