Increasing 110 tlb loader lift capacity
   / Increasing 110 tlb loader lift capacity #1
ME83
Western MA
JD 110 TLB
I have had my 110 for about 4 years now. The one thing I really wish it had is more lift capacity for the front loader. Comparing it's numbers to the 400cx loader, the 110 has about 13% more capacity. This seems like a very small difference especially when looking at how much heavier the 110 loader is built. The hydraulic pressure is already 3000 psi per spec (which is 17% higher than 4x20 series); the pressure seems high enough as is and I prefer to not increase it.
Has anyone here increased their hydraulic pressure on a 110?
I would rather look into swapping the cylinders out for a larger bore cylinder. Anyone done anything like this or have any concerns/suggestions?
Thanks,
Mark
   / Increasing 110 tlb loader lift capacity #2
Just keep in mind that the hyd cylinders on the 110 are the same grade/duty level as the construction side so are built to a different requirement than the cylinders for a 400x loader. Deere has a series definition for each cylinder grade, I am forgeting them right now I want to think they call the cylinders on the yellow stuff 200 series?? I only mention because you could end up going down in cylinder quality. How much do you want a #7-7,500 machine to lift?
   / Increasing 110 tlb loader lift capacity #3
My friendly advice is to leave it alone! The 110 has incredible FEL capability for the size machine it's affixed to imo. This machine like others has been professionally engineered and as such the components are all matched to each other. If you oversize one component another component will be directly affected and thus undersized.
   / Increasing 110 tlb loader lift capacity #4
Every now and then... I wish that the FEL would have a bit more lifting capacity. Although, I have found myself seriously wishing I hadn't picked up that heavy a load, too! That thought has crossed my mind just about the time that one of the rear wheels comes off the ground and the tractor is doing a 3-legged pirouet!
So, I've left well enough alone...
The backhoe unit with HD 20" bucket and thumb and cylinder guards is over 2,000lbs (1,980 with 18" bucket OEM). So, what type of rear ballast would you consider using if the loader capacity was increased?
AKfish
   / Increasing 110 tlb loader lift capacity #5
I want a hoe thumb...they're cool! Can you send a pic AKfish?
   / Increasing 110 tlb loader lift capacity #6
Here are some pictures of my thumb and hoe, 321647i_20.jpeg20120807_163630.jpgTLB 110 Clode up pics 002.jpgTLB 110 Clode up pics 003.jpg
   / Increasing 110 tlb loader lift capacity #7
Nice!!! There's been times where a thumb would have been really handy! Specifically concrete removal, seperating roots and dirt in a pile, cleaning my fence row (from either side), loading cross ties on a trailer and a million other chores/jobs!! An extendable hoe would be sweet too!! For that extra reach! I saw a backhoe the other day with a pivoting dipper arm. Not sure if I called that right but basically the backhoe pivots between the boom and dipper...crazy! Cool concept for digging right against a house footing or fence etc...
   / Increasing 110 tlb loader lift capacity #8
PBettis the thumb is one of those items that if you never had it you may not miss it but once you have had , used or seen one in action it becomes a must have.
There is a ytube channel of a guy from up here in Canada called Billstmaxx he has a TLB 110 and post allot of videos( many with the 110). He posted a series of videos of him making a thumb for his TLB110. You may want to check it out.
   / Increasing 110 tlb loader lift capacity #9
Have any of the 110TLB owners checked their releif pressures to see what the as found setting is? Wonder what the spec setting is also?
   / Increasing 110 tlb loader lift capacity #10
Here is a few photos that i had on file when i was looking for my 110 (stolen photos from web sites)
1.JPG14 Thumb - Clamp.jpg110.jpg110_thumb_001.jpg110_thumb_004.jpg110_thumb_007.jpg111.jpg106551104_6thumb_550x410.jpg0125070957a.jpgDSC04974.jpgJD_27ZTS_Thumb_010.jpgJD_35_ZTS_Thumb_001.jpgJD_35_ZTS_Thumb_003.jpgJD_35_ZTS_Thumb_104.jpgphoto (3).JPG
1987 FRUEHAUF 150BBL ALUMINUM TANKER TRAILER (A53843)
1987 FRUEHAUF...
SDLANCH ELECTRIC GOLF CART (A53843)
SDLANCH ELECTRIC...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
Makinex Electric Powered Hand Truck (A52377)
Makinex Electric...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
