Increase hydraulic speed on TC40D?
   / Increase hydraulic speed on TC40D? #1
Bernmeister
Ashland, VA
New Holland TC40D
I want to run an auger and trencher on the front of my TC40D (with bobcat disconnects and hydraulics) but I think my tractor only flows 9.8 GPM and trenchers use 15-25GPM. Can I just buy a bigger hydraulic pump? Any suggestions? These attachments are available for free if I could just use them. I have the 16LA loader with a 4-1 bucket and front hydraulics already. Thanks!
   / Increase hydraulic speed on TC40D? #2
There is nothing you can do that would be practical to supply 15-25 gpm using hydraulic components your tractor was built with. The tubing and valving will not accomodate that flow.
   / Increase hydraulic speed on TC40D? #3
Welcome to TBN:D
The only way you could do this is to build or buy a separate hydraulic system that is powered from your PTO. You still would be limited by horsepower though. This system would need the pump, tank, filter, valve, and large hoses and couplers and maybe a cooler...well over $1000 to get it working. It's just not practical-go rent a trencher for $100 a day;)
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2018 ASV RT30 Forestry Posi-Track Compact Track Loader Skid Steer (A55851)
2018 ASV RT30...
2016 Dodge Charger Sedan (A55853)
2016 Dodge Charger...
UNUSED WOLVERINE SBG-13 72W 83.2" SLIDING (A57193)
UNUSED WOLVERINE...
