Front-End Loader Inclinometer, Tilt-O-Meter, Angle finder? What to use to help with grading driveway?
   / Inclinometer, Tilt-O-Meter, Angle finder? What to use to help with grading driveway? #1
joea99
Platinum Member
Marbletown NY
Kubota B21, JD 240GT
Got a gravel drive, shared with neighbors. A "road" actually.
Got in a load of item 4 (with small aggregate). Item 4 as it is known here, is basically small stone with grit and stone dust. Road base, some might call it.
Anyway, I'm finding it rather tedious trying to get a surface to my liking.
Basically, I want to pitch the surface to direct run off to one side. Try as I might, once I back off a ways, I can see the pitch is what I want, so I guess my perception while "in the chair" is not too good. So, hoping some kind of tilt gauge might help. Looking at Amazon, etc, there are cheap and there are not so cheap.
Wondering what suggestions there might be. "Right tool for the job" may be suggested, but that is not in the cards.
Machine is a Kubota B21 with a "4-way" bucket on the front end.
I should add that one issue I have, as operator, is that I cannot see the front edge of the bucket, or the orientation of the blade, when "extended", or the bottom of the bucket is, when closed up. So that leads to me making "gouges" at times. That is just an additional annoyance I thought I would throw in the mix.
   / Inclinometer, Tilt-O-Meter, Angle finder? What to use to help with grading driveway? #2
If you're not dead set on buying something...just tape a spirit level ( 2' or torpedo will work) across the loader cross frame bar just behind the steering wheel...
   / Inclinometer, Tilt-O-Meter, Angle finder? What to use to help with grading driveway? #3
I have an application on my pocket phone that works very well.
Add a straight edge to sit it on, and grading a road would go DIGITAL! ;-)
   / Inclinometer, Tilt-O-Meter, Angle finder? What to use to help with grading driveway? #4
I have a R & B Mfg Model 15C to do exactly what you say. I have had it for years. Easy to read and responsive but smooth. My eye is like yours and I also pitch the road all the way across in some places. Harder to see than a crown. I just mounted mine with double sided tape. Here is a pic I found of it. Google R & B Manufacturing and look at the basic models.
gg
   / Inclinometer, Tilt-O-Meter, Angle finder? What to use to help with grading driveway? #5
gg
I have a R&B tilt meter and I just taped it to my box blade to grade/level our road.
2025 Ligchine Spiderscreed Concrete Screed (A55851)
2025 Ligchine...
2023 Kubota Z252KH-54 Zero Turn Mower (A55314)
2023 Kubota...
42013 (A51691)
42013 (A51691)
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2017 KUBOTA SVL75-2 SKID STEER (A52707)
2017 KUBOTA...
2018 John Deere 1025R Tractor - 257 Hours (A55314)
2018 John Deere...
