In Need of YM2200 Left Wheel Hub
   / In Need of YM2200 Left Wheel Hub #1
DannyV
Santa fe, Texas
Yanmar YM2200
I was doing some Hurricane Ike debris cleaning and my front left wheel came apart and fell off. I am trying to locate a used assembly to replace this broken one ASAP. I have a picture attached showing whats broke. If anyone has one please let me know. Thanks
   / In Need of YM2200 Left Wheel Hub #2
Kind of hard to tell from the pic about the hub but, it looks like you may have broken your kingpin. Hoye should have them
   / In Need of YM2200 Left Wheel Hub #3
I have the parts you need ( used )
Danny
   / In Need of YM2200 Left Wheel Hub #5
hi DannyV,
I'll suggest you try Private Messaging "1danny", he can / will be a lifesaver for a Yanmar.
I too see a Kingpin failure if I do not get off my arsh and replace the front inner wheel bearings. I foresee this happening to me. I'd bett your inner wheel bearings were shot and wore down the kingpin too failure. Dang, now I'm scared to keep cleaning up before maintenace is performed... bearings are still there but the inner bearings are wobbly as heck, the balls pop out the race and I'll be at Kingpin failure too.
EDIT: Get bearings and seals for both hubs, cheap insurance.
Good Luck
rhett
   / In Need of YM2200 Left Wheel Hub #6
hi again DannyV,
relooking at the picture, is the Kingpin shaft broke?
i think i see the Kingpin shaft intact with the retaining nut still in place?
if that is the case, you may only need bearings and seals...
if the parts were cleaned before taking a picture it shure would have helped. I'm getting old and going blind. everything in your picture seems to blend together. dirt everywhere.
anywho, I still need to maintain my little girl... she is a tough one !
   / In Need of YM2200 Left Wheel Hub #7
Same thing happened to my 2000 (D** Gopher turtles) replaced the bearings with sealed bearings from NAPA so far so good never did find the dust hub cover. Good Luck hope its only the bearings.
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2022 JOHN DEERE 85G EXCAVATOR (A51242)
2022 JOHN DEERE...
CATERPILLAR D6R XL CRAWLER DOZER (A51242)
CATERPILLAR D6R XL...
