in floor heating
   / in floor heating #1
woodsleeboy
ontario, canada
I'm thinking about installing in floor heating in my pole barn. My building is 28x40x12. Does anyone have any info on how to do it (without spending a fortune on a commercial system?) Can I use a domestic hot water tank?
   / in floor heating #2
Do a google search on "radiant floor heat" and "hydronic floor heat" and you will get a lot of good hits.
also try the radiant panel association at:
radiant panel
Water heater use as a source depends on your local code. In WI you cannot use a water heater unless the mfr has listed radiant heat as an approved usage.
   / in floor heating #3
I'm planning on doing the same thing this year in my 30X75 building. PM me and I will send you my favorites listing for my radiant floor project. I think I have about 30 listings.
   / in floor heating #4
Assuming that you intend on installing a concrete floor, not too long ago I saw a class action suit against the manufacturer of the tubing as it had a tendency to rupture after some period of time. Just something to think about.
Overall, I hear that the heating is even and comfortable, yet slow to respond to heating demands.
   / in floor heating #5
While it is possible for a remote leak on the non metallic tube like Wirsbo, in all the years I was in the HVAC industry I saw but one leak under a concrete floor and it was plumbed with copper.
   / in floor heating #6
This is how I did it. F/BB/WP reflective insulation underneath, wire to tie the tubing to and 600' of PEX tubing for a 24' by 24' area. I will be heating it with an outside wood boiler.
2024 New Holland T8.410 MFWD Tractor (A53473)
2024 New Holland...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
