Improving AM radio reception?
   / Improving AM radio reception? #41
We had medical equipment that required isolated ground... and special outlets so marked... it was to cut down on the "Noise" if I remember correctly...
   / Improving AM radio reception? #42
any quick and easy way to filter the AC voltage?
Probably not. It should have been done in the radio power supply and you would really need to know the frequency of the interference to try to target it.
BUT, perhaps you could mess with the external DC power supply to the radio? In the case of my CCrane radio, there is a "wall wart" (DC power supply) that plugs into a wall outlet and has a power cord (zip cord) coming out of it that plugs into a 6 Volt DC input jack on the radio.
Option 1 - changing the power cord position (move it around....try coiling and/or twisting it if possible) might help ....... some. Maybe even wrapping some aluminum foil around this cord will help....some.
Option 2 - Put ferrite beads on the power cord, real close to the plug that goes into the radio (Google "Ferrite Snap on Rings RFI/EMI Noise Filter") I see Amazon has a package of them for about $10 ..... way over priced, but super easy to order.
Option 3 - Power the radio with a 6 volt lantern battery (or even a lead acid golf cart battery that can be occasionally charged) plugged into this power jack.
Option 4 - Buy (or build) a better power supply than the wall wart supplied with the radio.
I suspect that a combination of options 1 and 2 will get you "most of the way" there. Option 3 should be close to purrrrfect or a really expensive power supply in option 4
In the case of the other radio with the built in power supply?????? Maybe you could put ferrite beads on output of the built in power supply, but this would be a more challenging task (if it is even possible) and you need to be careful to not do it while the unit is plugged in.....just in case you goof and grab the wrong leads:pullinghair:
Hope this helps.
   / Improving AM radio reception? #43
Strikes me you just might be North of Line A out there, and de radio itself might not be de problem. Whole bunch of stations North of Line A was required to downpower transmission year or so back which meant lousey signal in lot of places.
(removed), I'm glad to see you posting again. I've missed most of your latest posts but back in 2013 before you stopped posting for a few years you had some very entertaining stories and I advise anyone who has a little spare time to read some of your old posts for some award winning swamp humor. :thumbsup:
No wall warts for either radio. Just straight 110v into the back of each. In fact their plugs are interchangeable.
   / Improving AM radio reception? #45
What time of day you noticin de radio takes a dump? All day you added sumtin wid a switched power supply causin de noise. Could be dem new LED lights.
Got a HAM car headlight I wiggled a LED cob into few weeks back cause I could, and running on battery no RF interference. Running on LED power unit makes de radio go nuts. Switch plugs so dey on opposite sides of de phase to Neutral an radio goes back to bein happy.
Radio craps out after around sundown I stickin wid de line A thing.
Listen real careful when station IDs, lot of stations now announcing second call sign for de auxiliary fill in transmitters used to compensate fer Line A power down.
WHAM in Rochester 50kw station on clear chanel clear as a bell for years and reached few hundred miles gotta downpower now to keep somebody happy sounds like CB set now beginnin half hour to sundown. Also announcing WAIO fill station to de South. Signal 15 miles North stinks.
   / Improving AM radio reception? #46
Back den I got my fill of some CENSOR fellow here who an Anti Coonazz Bigot.
Got about accomplishin other things, a man wid 9 girl Harem can have his hands pretty full, say nuthin of his job box. Good part is generally population is missin a couple who off doin whatever dey do.
Got hooked on dese pills make my blood thin too to make de clown think he half de Doctor Granny Clampet was, an dey slowin me, puttin a tarnish on my Golden Years so to say. True to tell, old age not for cowardly men wid weak spines. I got bunch of in de house jobs in line for winter, and most de Harem knows way to my house. Gotta figure out how to hook my fancy phone to a TV I don't watch so I ain't gotta grab my readers to see dat miniscreen. Mans work is never done.
   / Improving AM radio reception? #47
OK.
Here are some more options then:
- Improve filtering in the radio power supply
- As (removed) said, find and fix the source of interference
- Google "EMI Line Filter" for some filters that may help. Most require hard wiring in, but you can probably do that in a (grounded) metal box or, better yet, inside the radio.
   / Improving AM radio reception? #48
Step one on ANY suspected interference issue is to run the radio off of batteries and then pull the main breaker to the house. Shut it all down. Then you will know if the interference is in your own house. Rejoice if it is in your own house, because then it is something you can do something about. Then flip on the main breaker, but power down all of the other breakers. While listening to the battery radio, flip on the other breakers one at a time. When the interference re-appears, then you have isolated the circuit where the interference maker lives. Look on the breaker box legend or go around the house to figure out what that circuit powers, and begin unplugging one at a time each appliance or lightbulbs on that circuit. Of course it could be more than one circuit breaker or more than one appliance or more than one lighting device, but you get the idea. Narrow it down. Obviously if the problem persist after you have thrown the main breaker, then that is bad news. It is likely NOT in your home. Now comes the onerous task of figuring out WHICH nearby neighbor is the problem. Or is it utility related? All of these problems are not easily solved.
   / Improving AM radio reception? #49
Just met up with a freind that does electrical distribution. Got four (I specified RF quiet) T8 Ballasts. Apparently that is not even talked about or requested in that industry, and they are a HUGE lighting distributer. He says I bought these before and was happey with them. I asked who buys these more expensive ballasts. He said School boards and hospitals. I asked why. Because they are INSTANT start. Instant as opposed to a fraction of a second later? Obviously there is more to it.
I will test them prior to installation. Since I may use them with LED retrofit T-8s, I wonder if those make any noise. That would be kind of futile.
   / Improving AM radio reception? #50
Good advice.
Clipper Walk Behind Concrete Saw (A57454)
Clipper Walk...
New/Unused 5ft Quick Attach Mixer (A57454)
New/Unused 5ft...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
2020 FREIGHTLINER M2 NON CDL 26FT BOX TRUCK (A59575)
2020 FREIGHTLINER...
20ft Jumper Cables (A57454)
20ft Jumper Cables...
2011 SHOP MANIFOLD TRAILER (A58214)
2011 SHOP MANIFOLD...
