Importing and modifying a new mini excavator from China
   / Importing and modifying a new mini excavator from China
I have now heard of three Chinese factories making, or about to make these 1-ton mini-excavators using CARB/EPA gas engines:
Shandong Loongsheen plans to use a Honda-clone 420cc unit just like my LCT. Jining Oking Tec Co has embraced the Briggs & Stratton XR2100 420cc engine. And Shandong Hightop has just decided to incorporate the B&S unit as well.
The Briggs 2100 is very similar to the LCT engine I am using, and I suspect it is also made in a Chinese factory, under the auspices of Briggs. US-based LCT (Liquid Combustion Technology) acquired the assets of Tecumseh years ago, and has one or more plants in China.
   / Importing and modifying a new mini excavator from China #142
Wow, they run these with about 7-8 hp.....
Is that enough?
   / Importing and modifying a new mini excavator from China #143
Clearance issues. They are used where zerts would get knocked off. Like door hinges where the snubber or guide arm would hit the zerts when the door is closed and the parts nest on each other. Or flight controls where the part the fitting is on (in?) moves under another part.
hugs, Brandi
"zerts" ?????
What are "zerts" ?????
Is that enough?
These 420cc OHV engines are rated about 13-16 hp at 3000-3600 RPM. For comparison,
the 500cc Changchai and Koop 1-cyl diesels are rated at about 12hp at about 3000 RPM. I have no
experience with those diesels, but 3000 RPM is pretty fast for a CI engine, and I suspect that
they are run slower than that because they make usable torque at lower RPM vs. the gas. Note
that the 700cc 3-cyl diesels in the Cat and Kubota both make only a little over 10hp, and I suspect
they are rated at 2500 RPM or less. Plenty of power, apparently.
The hyd pump is a bit too large on these Chinese machines (6.8cc), which makes them somewhat
jerky and hard to control. I am going to downsize to something like 5.5cc/rev.
   / Importing and modifying a new mini excavator from China #148
I didnt read every page of this thread but Im glad to see you had a good experience.
I'm looking for a new hydraulic pump for my Takeuchi TB145...I was quoted $4750 from a vendor here in the US but I found what I believe to be a direct replacement on Alibaba for $1600/shipped!
I'm nervous about buying such an expensive/complex part from a Chinese distributor...but that $3000+ savings is very tempting! I guess the stigma of chinese "junk" and "knock-offs" is just hard to get over. The seller sent me numerous pictures...it appears right, but who knows? Could be some chinese knock-off that lasts 100-hours and blows up. Is it worth the risk?
Yes, caveat emptor. Note that your $2000 cell phone is probably made in China.
Remember that with Alibaba you have "Trade Assurance", which is an escrow service that requires receipt and approval of your goods before the seller is paid. Both good and lousy stuff comes from China, but, with diligence, you may be able to find the good stuff.
As for your Takeuchi pump, that must be a variable piston pump, and I am surprised if there is a Chinese maker, as they usually use high-end hydraulic components from Europe, Japan, or the US. Or, is the seller getting a part from Japan, directly?
BTW, I am working with a partner here in CA to import 6 more of these minis, this time with EPA-certified B&S gas engines. And a 25% tariff.
   / Importing and modifying a new mini excavator from China #150
Yes, the one they showed me in the photos is a Rexroth pump, made in Japan. At least that's what's stamped on the tag.
With this "trade assurance", if I receive the pump and it's not what I bought, does alibaba refund the money?
Very cool about the mini-ex's! Are you planning to just resell them and pocket some $?
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56857)
2016 AutoHauler...
Yanmar YT359 (A53317)
7-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
7-Gang Reel Mower...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
