Implements?
/ Implements? #1
JCA
Maine
Kubota B7510
Hi folks. I've been shopping for tractors, but this morning I got to wondering if what I really need is a UV. But I don't know anything about them. I've got about ten forested acres, very hilly, with no shortage of rocks. Tractor would have more ground clearance but a lot less stability.
Here's the clincher, though. I see these things have some kind of hydraulics, and a pto (right?). So what kinds of attachments can you use them with, and how do you use them? I need to get a chipper out into my woods (up and down hills), and I need to remove snow. That 6-foot blade looks nice, but is it hydraulic? Can you move it around, angle it...or does it just sit there? What I'd really like is a snowblower--can you power one with, say, a Kubota RTV900, or similar?
Thanks!
Jim
/ Implements? #2
I don't know of any of the UV's that have a PTO. John Deere has an electric lift for their 6X4 Gators but the equipment availability is extremely limited. A UV is no replacement for a tractor. Maybe someone can shed some light on what the Kub RTV has.
/ Implements? #3
Jim--ATV's and utility vehicles supplement but definitely do not replace tractors. None of these vehicles have engine-driven PTO's, much less three-point hitches. The Kubota is as far as I know the only one with any sort of remotes, because very few of them have hydraulic drive systems. You certainly can pull a standalone chipper out into the woods with something like an RTV, Ranger or Gator, but obviously it'll be something like a DR chipper with its own power plant. As far as a snow blower goes, there are engine-powered models built for ATVs, but they are really pricey. Happily for you, the answer is obvious: You need at least one of each!! /forums/images/graemlins/cool.gif
/ Implements? #5
I believe the Toolcat is in the $35K range.
/ Implements? #6
Or a Unimog.
F/R 2 speed PTOs
F/R multiple hydraulic hookups
3 point hitches, too.
/forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif
Have a good one,
Neil.
/ Implements? #7
Yeah, no UV has a PTO drive. The Kubota RTV900 < http://www.kubota.com/UV900/top_2.html > does have remote hydraulics for use with low-pressure hydraulic tools (standard on Turf model & accessory option for other models). See this thread for more: < http://www.tractorbynet.com/forums/showflat.php?Cat=0&Board=atv&Number=399801 >
The snow blade for the RTV900 is not hydraulic (made by Curtis Cab). It has a eletric powered lift to raise the blade and the blade can be angled in several ways. Here are the basic specs:
Curtis 72" Front Blade
Standard power lift and 5- position manual angle.
Extended push frame for toughness.
Reversible 1/4" x 5" - high carbon steel cutting edge.
Heavy duty trip springs (5/16" dia. wire x 10" length).
4 Pin detachment - seconds to remove.
12 - Volt lift/lower switch with harness included.
I don't think you will find a low-pressure hydraulic snow blower for a UV, it probably will have to be a self-powered blower of some kind.
It sounds like the RTV900 (9k-11k retail) is probably your best bet unless you have 35k to spend on that Bobcat or UniMog.
/ Implements? #8
Yes, you can get a light duty 3-pt hitch (cat 0) for your ATV/UV and a pretty wide variety of implements (select "products" from the menu on the left on this page )
That being said, tractors and ATV/UV's are entirely different beasts. If you are doing "serious" land manipulation, there's no contest: Tractor wins. But, for hauling stuff and getting around the property quickly/efficiently, ATV/UV wins.
Both are very useful, but don't overlap in job descriptions very much. 'Round here it is very common for farmers/ranchers to have both a tractor and an ATV/UV - they're just that different.
/ Implements? #9
It's too bad the Curtis plow doesn't take advantage of a hydraulic pto to adjust the blade angle. You mentioned that the lift was electric. Does a electric motor supply hydraulic pressure to a piston that does the lifting/lowering? The photos I've seen seem to show some sort of hydraulic device or is that some sort of shock absorber to dampen the lift?
I assume the power steering is also a byproduct of the HST transmission or does it have it's own pump?
Thanks.
/ Implements? #10
Yes, I think it is an electric over hydraulic lift. The power steering has its own hydraulic valve (pump) and cylinder if I recall correctly. I'll double check and reply back if that is wrong. My memory is bad sometimes. hehe /forums/images/graemlins/grin.gif
/ Implements? #11
I did some investigation and the power steering is powered by a gear driven pump on the engine (indirectly driven by crankshaft). /forums/images/graemlins/smile.gif
Welcome to the Ranch Metal Decorative Sign (A64557)
Welcome to the...
2003 FORD F-750 SUPER DUTY(INOPERABLE) (A67714)
2003 FORD F-750...
2018 Ford Focus (A61574)
2018 Ford Focus...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
CAT 621B Transmission (A68134)
CAT 621B...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
