Implements rebuild questions.
   / Implements rebuild questions. #1
Mowens
Mitsubishi MT160
Ok 2 questions. Assuming no cost for steel.
1. I have a 5' bush hog the top is toast the gearbox is top notch. Frame kind of sketchy as well. So is it worth rebuilding into a 4'? I figure i can cut 6 inches off each side and narrow it it down. Figure length does not matter.
2. I also have a 4' disc that was built for a draw bar. Is it feasible to convert to 3 point? I think the best way would be to make a frame the gangs to bolt too.
   / Implements rebuild questions. #2
The tip speed would be lower as a 4ft. And have to rebuild the stump jumper or shorten blades. Unless I needed to get into narrow spots, I think I would leave it 5ft and go slower or partial cut if needed.
For the disc, I would look at other 3pt discs and copy the one I liked.
Bruce
Thanks. Yea its the trails im working through they run about 4+ feet. That's the whole issue. It's leased land I can't go chopping trees down to widen the trails.
Thanks for the advice. I think the land pride tube frame looks simple just a square frame with arms for the gangs and the 3 point
   / Implements rebuild questions. #4
Do you have a boom pole? Perhaps leave it as a towed disk and use a boom pole to lift it up?
Aaron Z
   / Implements rebuild questions. #5
on the cutter you would at least need to buy new blades and possibly even a stump jumper + your labor to repair it.
Im not sure how the used implement market is in your area but down here Ive seen 4 ft disk, and cutters $300-400
Well no boom pole.
It already needs new blades so that's going to happen either way. It dosent have a stumpjumper at all just a straight bar mount.
I'm in South Alabama on the coast. 4' implements seem hard to find. New I can order at 6 or 700 but that gets pricey.
Appreciate all the advice.
I think I'm just going to cut the sides down make it 4' wide leave it longer and get shorter blades. Keep it easy.
Make a box frame. And move the gangs over.
2017 Ditch Witch FX50 T22S Towable Vacuum Excavator (A55973)
2017 Ditch Witch...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Extended Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
2000 INTERNATIONAL 4700 (A58214)
2000 INTERNATIONAL...
2005 FORD F-150 XL (A58214)
2005 FORD F-150 XL...
Club Car Electric Cart (A55758)
Club Car Electric...
