Implements operate jerky
   / Implements operate jerky #1
Wood Hound
Houston, TX
Mahindra 3016
The rear implements on my rear top-n-tilt operate very jerky when changing position when moving in down direction. My restriction orifice doesn't seem to help. How does the orifice work and on which hydraulic line. Are there any other recommendations to smooth out the operation?
   / Implements operate jerky #2
Restriction orifice needs to be in the line that control flow out of cylinder when lowering or moving via gravity especially if you have PO check in the circuit.
   / Implements operate jerky #3
A couple of things. You will find that the whole system works better to have a flow restrictor at each port.
So you should have 4x .030 restrictors for your top & tilt set.
Second thing, try feathering the controls.
2007 Ford Explorer SUV (A55758)
2007 Ford Explorer...
2017 Nissan Frontier Pickup Truck (A53422)
2017 Nissan...
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
UNUSED WOLVERINE JMR-22-8.5G 1R RIPPER (A54757)
UNUSED WOLVERINE...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
