implements for 2015
/ implements for 2015 #1
xcsm
I have a Mahindra 2015HST 4wd and would like to know if 4' or 5' implements are recommended. I will probably purchase a tiller, box blade and bushhog. Appreciate any feedback.
/ implements for 2015 #2
xcsm, the 4' implements are what is most suited to the 2015. Rakes and angle blades are the only implements you could use wider than 4'. For example, a 6' grader blade, used on an angle for road grading would still cover your tracks.
/ implements for 2015 #3
I had a 2015 for about 3 years. I could run 5' stuff but only because I had them. I would recommend 4'. You will be happier.
/ implements for 2015 #4
My brushog is the only 4-foot implement I have for my 2015. My rear blade is 6-foot. My landscape rack and box blade are both 5-foot. I live on the side of a mountain, with a very steep driveway. Those size implements work very well with the 2015. I can go up the steepest part of my driveway with the boxblade pulling a full load of gravel. I had a 5-foot rear blade, but it was too small to do a decent job of cleaning ditches and clearing snow, so I traded it for a 6-footer.
2012 Ford F350 Truck (A62679)
2012 Ford F350...
2012 International 4300 Reefer Truck (A63689)
2012 International...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
2005 GMC TOPKICK C6500 TESTING UNIT (A65643)
2005 GMC TOPKICK...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
