Implement sheds?
/ Implement sheds? #11
Paint it black and it looks like a stealth fighter. /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
/ Implement sheds? #12
I built a 16' x 16' "pole barn style" shed. The floor is 3/4" pressure treated plywood. I believe it is the best floor because:
1 it stays dry
2 it's smooth and flat
3 won't rot
4 easy to clean
5 easy to work on equipment
6 easy on the knees & back
7 holds heavy machinery (using 2 x 6's for joists)
/ Implement sheds?
<font color=blue>Paint it black and it looks like a stealth fighter. </font color=blue>
Funny thing is that was my exact thought as I looked at my "masterpiece" while taking the photos.../w3tcompact/icons/smile.gif
Bill
/ Implement sheds? #14
Ok, here is a pic of a structure I made for my finish mower and other small odds an ends, after the 8N took its spot in the barn.
Soundguy
/ Implement sheds? #15
another view of that shed
soundguy
/ Implement sheds? #16
And here is the reason I had to build that shed in the first place... as there -used- to be room in the barn for the finish mower, .... but I added a mini horse, and the old 8N.
Soundguy
/ Implement sheds? #17
Are the joists at 16 center? Do you have any trouble with oil on the plywood? Can you show some pictures?
PJ
/ Implement sheds? #18
I doubt pt plywood is going to have a problem with oil, other than absorbing a nice permanent stain.
You could always apply a sealing agent on the top side, and just clean up the spills before they solvated the sealing agent... or use something more permanent like urethane.
Soundguy
/ Implement sheds? #19
bill, why don't u take the pto shaft off the mower and put in further underneath, also i beleive some plastic stapled to the plywood and anchored down in the ground would be better cover for the wheels. as per JM3 TRY AND GET IT OFF THE GROUND. and grease it well.
/ Implement sheds? #20
Sheds aren't such a problem but when I started my digging for pouring of a cement footing, I checked one more time and found that I was a foot short and a foot too narrow for my drive through tractor/snow mobile building. Plus I knew I would want/need more to store so it expanded in length and width to 20X20. Easier to build it once than add on to.
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
Iranch IRGC40 (A60463)
2006 TAKEUCHI TB135 EXCAVATOR (A62129)
2006 TAKEUCHI...
HEAVYEQUIPMENT TIRES (A60736)
HEAVYEQUIPMENT...
2002 WACKER RD25 ROLLER (A59906)
2002 WACKER RD25...
