Impact screw drivers?
/ Impact screw drivers? #21
I have the 18v Dewalt set. I managed to convert my dad and grandfather over from drills. My FIL converted me. It's about 8or9 years old. Use the impact all the time. To give you some idea of the 1/4 inch strength. I needed to put 1/2"x10" lags into the barn. My drill bits weren't that long but I pre drilled as deep as I could. I could put a lag in before my 1/2" air impact could. I was using a pancake compressor and it would run out of air. That battery impact could do one and finish the air impact's before compressor could catch up.
Screws are just as fast. But spend the extra money and buy the impact ready bits. They last a lot longer.
/ Impact screw drivers? #22
Oh, gosh, next visit to Harbor Freight is going to be expensive.
You talking about one of these?
18 Volt 1/4 in. Cordless Variable Speed Hex Impact Driver
Gosh I guess they don't come cheaper than that! :D
I grabbed my Milwaukee 18V 2 speed impact compact driver kit (2) 1.5 amp batteries case and charger New 5 yr warranty for $89 during an HD one day sale. It was 90 off reg. list price.
MilwaukeeTool has just announced that they are replacing the standard line of brushed 18v drills and impact driver with new brushless models at the end of the month. I just bit the bullet on a brushed 18V hammer drill kit at 25% off. I'm sure they will be some more serious sales on the current stuff.
/ Impact screw drivers? #23
With the hex to 1/4" square or 3/8" square adapter bits they can use sockets too. And they are pretty handy for assembly and removal without dragging out the air hose. Now it aint gonna torque the lug nuts on your tractor, but for small fastners it is handy.
I have a high-torque cordless impact driver from Bosch:
Bosch 18-Volt Lithium-Ion Impact Driver Bare Tool (Tool Only)-25618B - The Home Depot
But I got mine in a kit with a nice steel-chuck hammer drill, two batteries, and a charger. You can find pretty good deals on Amazon.com (I paid ~$250).
It does 1500 in-lbs of torque, which is 125 lb.-ft. That's plenty to remove properly torqued lug nuts on most cars. I have adapters for 1/4", 3/8", and 1/2" sockets and use it when I switch between summer and winter wheels/tires when the seasons change. Heavy-duty trucks and tractors are another story, obviously. It's also variable speed, so you can run it really slowly if you have to run in a ton of screws with low torque (into plastic or something).
Now that I've had mine, I wouldn't be without it. I certainly wouldn't drive a screw with a cordless drill again. Every friend I've had come over and wrench with me has immediately decided to buy one just like it. They're that awesome.
/ Impact screw drivers? #24
NiCd batteries are dinosaurs. Li-Ion are more robust (fewer worries about memory, cycle failures, etc.), higher capacity, lighter, and longer lasting. Don't buy a new cordless tool with old battery technology.
/ Impact screw drivers? #25
Ooh I wont...I wonder if I can ever find someone to buy my NiMh Makitas :)
/ Impact screw drivers? #26
Yea, I think my milwuakee is like 1600 in-lbs or something crazy for such a small tool.
How much of it is hype i dont know. Given the little 1/4" hex shank, I wouldnt use the tool everyday nearing the 130ft-lbs it claims. Got the Air impact for that.
They are impressive no doubt. But no replacement for an actual impact in certain applications.
/ Impact screw drivers? #27
I still have a 12V Dewalt cordless drill. It's probably 20 years old, it's fallen off a 2-story roof, been kicked/dropped/dragged, and terribly abused all its life and it still runs great. However, it's been through a bunch of sets of batteries in that time. After the last set died (none last more than a few years), I put it into its case and on the shelf. I should really toss it...
/ Impact screw drivers? #28
I have a 20V Lith Ion Dewalt impact driver and I like it a lot, also have a 1/4" drill driver that takes the same batts... AND two drill drivers that use 14.4 V batts, all have been dependable, but the LI batts really are superior!!
SR
/ Impact screw drivers? #29
Like everyone else said, impact are far superior for
- larger screws, 3.5 and 4 inch screws in tough wood no problem
- less tiring, drive them all day.
- faster than pre-drilling and then driving the screw, and way easier than switching drills and bits on a ladder, etc
- better on batteries and will last longer, especially when driving larger stuff
and everything else said so far.
I would add...
-They are louder, you should wear earmuffs especially when holding it near your head like on a ladder
- they are so powerful that even with a variable speed trigger, I often choose the drill for small stuff
but those is the only cons I can think of
What no one has mentioned is:
- that a drill is not designed to come to a stop, and it will burn out if you are driving big stuff and it stops. I burned out three cordless drills abd one corded one in three years. Then I got an inpact and regular drill combo and about 4 years later they are both still working fine.
- Far superior as a nut driver and faster than a socket set in many situations. Just use a wrench or socket to hold the bolt head and drive the nut with the impact driver.
- I drive carriage bolts with it when fencing, although that sometimes needs to be pre-drilled just to avoid splitting the post.
If you are working on big stuff, outside with big screws (fences, furniture, etc), there really is no comparison. Get an impact driver, you will wonder why you didn't do it earlier.
/ Impact screw drivers? #30
First impression left me wanting. For some reason I got an offer for an 18v 1/4" Milwaukee Impact driver kit for about $80 and thought I would give it a try. I have used it to drive only about 40 3 1/2" Decking screws and other than the extra noise of the impact driver (which is irritating for me) did not see what all the fuss was about. Sounds like they are better for battery life but if you only drive a few hundred screws a year I wouldn't bother spending the money. They are smaller than my cordless drill which is a positive.
/ Impact screw drivers? #31
Tractor lugs no probably not :D
First weak point is going to be the adapter probably snap and from what I understand the further out your extension is the less power is transfered
I will tell you guys though I am seriously impressed with ALL my socket ready anvil drive Milwaukee impacts though even the little 12v 2463 @1200 in/lbs took all the clean and properly torqued lugs off of my dual axle trailer with 15" wheels. I was surprised :shocked:
It did balk on the old Dodge truck of mine been sitting for 4 years now...got a few of the rusted and damaged lugs loose on the 16" wheels no way was made for that abuse :laughing:
But the FUEL 18V 2655B I have hasn't failed me yet and its a heck of a lot lighter than that monster 2763 which I think is the best you can get in a cordless impact. That is supposed to make UP TO 1100 ft/lbs of breakout power.
Go where no air hose has gone before :rolleyes:
You can check out most reviews on youtube
/ Impact screw drivers? #32
I bought the DeWalt 18V drill & impact driver set 4 years ago. The impact driver is great for screwing down metal roofing/siding. Just a bit of pressure, and it pierces right through. No dancing around like a drill. Just got to know when to say when. Drive it down close, then bump it a couple of times to seat the neoprene washer.
For wood screws, I like to use a drill & drive. Pilot hole & countersink, then flip to drive. 99% of the time I use square drive screws. No camming out like Phillips head screws.
And I usually put a dab of beeswax on the tip of the screw to make it drive easier, do this with framing nails too. Even in oak, they go in like they have eyes. With them driving easier, I get longer battery life, between charges.
/ Impact screw drivers? #33
Impacts typically have the ability to generate more torque than a drill. (sink bigger screws or lags).
They can do this without breaking your wrist or yanking the drill out of your hand like a conventional drill. So thats a +1
They are typically a LOT easier on batteries than a drill. So you can sink more screws per charge +1
They are alot less likely to strip out the heads. Especially phillips screws due to the impacting +1
Impact drivers are usually lighter. +1
All in all a impact driver is made for sinking screws. A drill is made for drilling. I have a few M18 Fuel milwaukee's. Those impacts are 3-speed.
What he said ^. This sums up my experience also.. I have driven thousands of screws with a regular drill, but after my wife bought me a cheap ryobi cordless impact, and I drove a bunch of big deck screws with it.. Man, I will never do serious screwdriving with one of my many drills again. Sure if the work is light a drill is just fine, but when you really want to sink some big screws rapidly, with less fatigue and an overall better experience .. yep an impact driver for sure.:thumbsup:
/ Impact screw drivers? #34
Agreed, I have bought my last NiCad, or Nickle Metal Hydride. I still have a couple of drills running on them, but switching out as fast as I can. So is everyone else. Just too many advantages to the Li-Ion.
/ Impact screw drivers? #35
That's one nice thing about the Dewalt's. Their regular NiCad battery or their XRP NiCad or their Li-ion battery's all fit the same tools as long as the voltage is correct. Other brands maybe the same.
/ Impact screw drivers? #36
The biggest difference I noticed with the impact driver after driving screws all day installing ductwork is not getting the wrist twist every time the screw bottoms out, After a while using the regular drill gun the wrist gets a bit tender.
The impact gun is my go to for everything except drilling holes.
/ Impact screw drivers? #37
I think all the advantages have been mentioned. I never use a drill except to drill now. Light weight and no torque going to your wrist. Try to drive a 3 inch deck screw with 3 fingers with a drill. Easy peasy with impact. Lithium ion batteries are amazing. Don't run down when not being used.
/ Impact screw drivers? #38
Yes that is great to have an option like that. I think Ryobi is also like that with their One system but I could be wrong
Best I can hope for with my older Makita's is an aftermarket adapter that engages the tool first and then you can slide the new style LION battery. At $35 each its hard justify having one for each cordless tool :(
Hey but at least the option is there to keep the tool viable for future use.
Trivia...did you guys know that the Milwaukee and Ryobi brands are owned by the same company?
/ Impact screw drivers? #40
The 2462-22 Milwaukee 12v kit was only 79.99 brand new for me with 2 batteries charger and case
Just before Christmas the M12 drill and impact combo was only $99
2019 CATERPILLAR 299D3 SKID STEER (A65053)
2019 CATERPILLAR...
2006 BOBCAT 5600 TOOLCAT UTILITY WORK MACHINE (A63276)
2006 BOBCAT 5600...
2005 Toro Workman Utility Cart (A64194)
2005 Toro Workman...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
1024 (A63111)
1024 (A63111)
2017 Chevrolet Silverado 1500 Pickup Truck (A64194)
2017 Chevrolet...
