Impact screw drivers?
/ Impact screw drivers? #241
No I have not used one
But I guess I miss your point :confused3:
What does making a single cut with a battery powered tool have to do with continuous duty operation
Several cordless models have shown to cut faster than a corded version
With my cordless circular saw there is only so many of inches of plywood it will cut before the battery runs down and needs to be recharged
Impressive tool none the less
My M28 stuff is used throughout the day and it is as strong as the plug in stuff with the added no cord flexibility of being able to be used out in BFE. Batteries take about 30-45 minutes to fully charge and by the time one battery is getting weak, the other battery is ready to go.
/ Impact screw drivers? #242
:thumbsup:!
/ Impact screw drivers? #243
What I would love to find are star-drive bits that have the 1/4" quick-connect hex end for my impact gun, and have an impact gun rating for durability (standard torx bits do not).
Home Depot and Lowes has lots of them. I prefer the Milwaukee brand bits because they seem to last quite a bit longer then the other brands. I've always had trouble with DeWalt, and I've found that their tips tend to break fairly often, but because that's all they had the last time I needed some while at Lowes, I bought a new version of DeWalt bits for impact drivers with a little yellow color on them. These are new and I've found them to be very good. Bosch also makes good bits, but they are hard to find. Lowes used to carry them, but they have gone all DeWalt and lesser brands.
Eddie
/ Impact screw drivers? #244
What I would love to find are star-drive bits that have the 1/4" quick-connect hex end for my impact gun, and have an impact gun rating for durability (standard torx bits do not). The bits that come with each bucket of star-drive screws are short bits made to go in a magnetic holder. While they work OK, it's hard to find a magnetic holder that will stand up to the repeated loads of an impact gun. Plus, the screw head holds on to the bit so well, it will often pull the bit out of the magnetic holder when you go to move the gun after driving a screw.
Your asking about bits similar to these right?
Star Drive Bits - Rockler Woodworking Tools
They have a good bit display of all sized impact ready bits on the counter at the independent lumber yard/hardware store I deal with.
I also have been buying the longer hex shanked bits often now and not using a bit holder
I have had the same issue many times especially with square tips staying with the screw head but guess its better to too be too tight than too loose.
My Milwaukee magnetic bit holder is very nice. A lot of the really cheap ones china junk don't even spin true. Wobble so bad especially at the high rpms a lot of these tool spin at. I bring my drill in with me and sit at the counter checking them until I find one I'm happy with :D
I bought some from TSC like that..pure junk. For $5 was 3 different length bit holders and 3 sized socket adapters. The adapters I like and work really good so it wasn't a total waste of money and actually ball lock on a impact socket better than the Milwaukee brand I also have.
At the lumber yard they also sell the ones with the knurled collar you pull back first to insert the tip. You can hammer on one of them so bad you'll need pliers to get the bit out. Really no good for impacts
/ Impact screw drivers? #245
Eddie
FWIW, I've had really good luck with that little, 38 piece Milwaukee bit set.
FREE SHIPPING — Milwaukee Universal QUIK-LOK Drill and Drive Set — 38-Pc., Model# 48-32-1500 | Steel Drill Bits| Northern Tool + Equipment
As well as the Bosch Daredevil Spade bits for impact drivers.
Bosch DareDevil Spade Bit Set (13-Piece)-DSB5013P - The Home Depot
After using good spade bits with an impact driver, I'll never use an auger bit again!
/ Impact screw drivers? #246
I have a couple of older Craftsman 19.2 V tools from a kit (drill + flashlight). The Ni-Cd batteries have reached the point where they no longer will hold a charge. I noticed that Sears now sells a kit that looks the same, with the same voltage, but Li-Ion batteries. Does anybody know if I could use one of these Li-Ion batteries to power my old (otherwise useless) cordless drill and flashlight (ie, are they interchangeable with the old Ni-Cds)?
Bob
/ Impact screw drivers? #247
Home Depot and Lowes has lots of them. I prefer the Milwaukee brand bits because they seem to last quite a bit longer then the other brands. I've always had trouble with DeWalt, and I've found that their tips tend to break fairly often, but because that's all they had the last time I needed some while at Lowes, I bought a new version of DeWalt bits for impact drivers with a little yellow color on them. These are new and I've found them to be very good. Bosch also makes good bits, but they are hard to find. Lowes used to carry them, but they have gone all DeWalt and lesser brands. Eddie
Eddie, I also like the new Dewalt impact bits. The Bosch bits were the best but didn't hold up in an impact. The last ones I bought for a phillips I couldn't drive but 5-10 3.5" screws before they would shatter. That's when I switched to impact rated bits which have only gotten better. They were hard to find about 3 years ago but now are plentiful. Also Menards has some Power Force(I think) double end impact bits that are holding up very well.
/ Impact screw drivers? #248
Bob
Old Ni-Cads can be rebuilt at your local Battery store.
/ Impact screw drivers? #249
Bob
I know that I bought LiIon batteries for my NiMh Ryobi tools and they work just fine.
/ Impact screw drivers? #250
Yes they do. In fact better than fine.. But remember you had to have a charger that was compatible with the new LI-ON batteries. The new charger will charge both the LI-ON batteries and the old NIMh batteries but the old charger will not charge the new LI-On batteries. All of my older NiMh batteries have bit the dust, and I don't intend to have them rebuilt.. I will just put the money towards the new Li-On batteries and go on.
/ Impact screw drivers? #251
The other day I visited a friend at a townhouse development where a crew was remodeling the front porches - railings, posts, balusters, overhead moldings, window and door trim. There were about eight guys working on three porches at a time. There were just two extension cords on the job. One leading to a 2ft x 4ft piece of plywood holding a bunch of DeWalt and Makita chargers, the other to a sliding miter saw. Other than that, every tool they had was cordless - circular saws, sawzalls, sanders, nailers, drills, impact drivers.
I watched them while sitting with my friend. They were very busy but I did not see anyone stop to get a fresh battery. I particularly noticed the lack of extension cords which are always underfoot or getting snagged on something or tangled up.
Although I've shifted to cordless hand-held tools myself, I hadn't thought about the difference cordless tools might make on a jobsite. Not having cords all over the place makes for a smoother workflow and is no doubt safer as well.
/ Impact screw drivers? #252
You are correct. I forgot until you mentioned it that I bought the new Lithium batteries in a kit with a new charger. I tossed the old charger along with the old NiMh batteries.
I think the general rule is that if Lithium batteries will fit in the tool then they will work. The companies are pretty careful to engineer both the batteries and tools so they are compatible.
/ Impact screw drivers? #253
As an aside, I just did a simple household project putting in a new wireless doorbell. I grabbed my 18v drill at first and then put it down and got the little 12v lithium Bosch impact driver. So small and light that you barely know it is in your hand yet it has all the power you would need for household chores. I wouldn't try to drive 3 inch screws regularly but 2 or even 2.5 would be no issue. And, you can get it into virtually any space you can get your fist into. Remarkably useful.
Amazon.com: Bosch PS21-2A 12-Volt Max Lithium-Ion 2-Speed Pocket Driver Kit with 2 Batteries, Charger and Case: Home Improvement
/ Impact screw drivers? #254
I have the same Bosch 12v set. I used the drill with a drywall bit to hang 900 sq ft of sheetrock on the ceiling in my shop a few months ago. It is light and extremely easy to modulate driving screws in old trusses of varying density to get a perfect dimple with every screw.
/ Impact screw drivers? #255
I don't care much for the Milwaukee shockwave bits I have and I probably wont buy them again. I'm fine with the bits I get at the local lumber/hardware store. I will have find who makes the ones they sell in bulk.
A while back pro tool did some testing on some different brands of bits
/ Impact screw drivers? #258
Some packs are in sealed plastic cases. They break when you try to open them. Not rebuildable.
larry
/ Impact screw drivers? #259
larry
I have heard that rebuilders cut the sealed packs apart and epoxy them back together.
I have some older ridgid ni-cad 18v batteries that need to be rebuilt. They are screwed together so it is easy to get inside. I'm considering buying the cells and doing it myself but I'm worried about the heat if I solder. The originals look like the tabs are sort-of "punched" into the cells. Looking online I have seen people build little spot welders for this purpose but it doesn't seem worth the trouble for 2 batteries. I may send them out to be done.
/ Impact screw drivers? #260
Until this thread, I had never used or considered an impact driver. I bought a HF 18V driver on sale because of this thread.
I just used it, first time. Drove 16 stainless steel screws. I am amazed how easily they went into metal following a drilled pilot hole.
The heads of 2 screws snapped off although I had been warned by reading posts of others who, too, snapped screw heads.
My net...wish I had heard about impact driver sooner. If you don't have one yet, get one. And, truly, it will not booger phillips heads, even when extremely hard to drive into material.
PALLET OF CULTIVATOR PARTS & FERTILIZER APPS. (A64278)
PALLET OF...
JOHN DEERE S690 COMBINE (A64278)
JOHN DEERE S690...
2014 CATERPILLAR 336EL H HYBRID EXCAVATOR (A65053)
2014 CATERPILLAR...
2021 BROWN & HUBERT 10' SPOOL TRAILER (A63276)
2021 BROWN &...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
2017 Ford E-450 Super Duty Shuttle Bus (A64556)
2017 Ford E-450...
