iMatch AutoHitch
/ iMatch AutoHitch #2
How many implements are you planning on buying?
Are you OK with buying John Deere implements only (meaning those implements that require a PTO hookup)?
I don't think the autohitch would work with other manufacturers' powered implements.
/ iMatch AutoHitch
I did not know that! I have three attachments and all three are a different brand. I had not thought of the autohitch and then I started noticing some on photos from this forum, so I thought I'd ask.
If I need JD attachments to hook up to the PTO, then I guess I have to forget it......
/ iMatch AutoHitch #5
The i match would probably work fine with most brands of rototillers. All that is changed on the tiller is a simple slip clutch and if the gear case shaft is a simple 540 spline then it will work fine. Rotary cutters are more involved and probably not worth adapting to a different brand.
/ iMatch AutoHitch #6
I have an Imatch and a few Frontier implements, along with a 6ft KingKutter tiller, and some off brand stuff like a cultivator, and they all fit great. The only one that will not fit, is a cat3 subsoiler, then I have to take the Imatch off. But, I don't use it but once a year or so.
Sterling AT (A63689)
John Deere 412R (A63688)
John Deere 412R...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
