iMatch AutoHitch
   / iMatch AutoHitch #1
FishHaggis
John Deere 2320
worth it or not?
   / iMatch AutoHitch #2
How many implements are you planning on buying?
Are you OK with buying John Deere implements only (meaning those implements that require a PTO hookup)?
I don't think the autohitch would work with other manufacturers' powered implements.
   / iMatch AutoHitch
I did not know that! I have three attachments and all three are a different brand. I had not thought of the autohitch and then I started noticing some on photos from this forum, so I thought I'd ask.
If I need JD attachments to hook up to the PTO, then I guess I have to forget it......
   / iMatch AutoHitch #5
The i match would probably work fine with most brands of rototillers. All that is changed on the tiller is a simple slip clutch and if the gear case shaft is a simple 540 spline then it will work fine. Rotary cutters are more involved and probably not worth adapting to a different brand.
   / iMatch AutoHitch #6
I have an Imatch and a few Frontier implements, along with a 6ft KingKutter tiller, and some off brand stuff like a cultivator, and they all fit great. The only one that will not fit, is a cat3 subsoiler, then I have to take the Imatch off. But, I don't use it but once a year or so.
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
John Deere (A50322)
John Deere (A50322)
2012 FORD 4 DOOR TAURUS SEDAN (A54607)
2012 FORD 4 DOOR...
TAKEUCHI TL12R2 SKID STEER (A52705)
TAKEUCHI TL12R2...
TEST BID LOT (A50775)
2017 Ford F-750 Altec LR758 58FT Insulated Bucket Truck (A52377)
2017 Ford F-750...
