Image Resize
   / Image Resize #1
TractorGuy
Elite Member
N. FL
John Deere 4310 CUT, Ford New Holland 575E Industrial Backhoe, John Deere F725 Front Mount Mower
It would be nice to have the option to resize the uploaded image view without having to go to the advanced screen. I have noticed I can do that from the quick reply window in other forums so it must be a setting.
   / Image Resize #2
I start in the advanced screen by double clicking any of the three "Reply" icons.
Then you can select from 3 larger than thumbnail sizes by double clicking the picture after it uploads.
"Large" only works on pictures less than around 650 pixels wide. It used to be 555 pixels wide, but it seems something changed and it is wider now.
If you use "Large" on a picture that is too wide, the right side will be cut off at whatever the current limit is.
   / Image Resize #3
I have three software programs that I can "massage" pictures with. Photopad is quick & easy. Movavi Photo Editor is more complex. I do all my resizing, cropping, editing before uploading to TBN. I also have an edition of Adobe but that's extremely technical and I only use it occasionally.
   / Image Resize #4
I start in the advanced screen ...
I edit, crop, color adjust all pictures before uploading anywhere using IrfanView. It's free and it works well for more things, but misses on some.
   / Image Resize #5
The problem for me is after uploading most posters leave it "Thumbnail" size, so it has to be clicked to see if I want to look at it.
If it is resized to "Medium" after posted, it can be seen. Then you can click it if you want more detail in a larger picture.
   / Image Resize #6
I use the method X prescribes. He actually taught me that method. Most times I use full size. I'll start experimenting with large or medium so I don't take up so much space.
   / Image Resize #7
Testing to see the maximum pixel width displayed in "large".
This is 750 pixels wide, 879 pixels high:
Edit: That works in this forum.
   / Image Resize #8
Resized to 850x994:
Trying 1280x960
Edit" I guess this forum doesn't have the old width limit on pictures posted "Large".
   / Image Resize #9
Richard, your resized pictures are fine. It is the 4,000 or 5,000 wide pictures that use too much bandwith.
   / Image Resize
At least some of you have missed the point. I resize all my photos to 1400 px on the long side at 96% quality using Irfanview. This keeps the file size below a MB. Usually 300 to 600 kb.
The request is to be able to use the "Quick Reply" window at the bottom of the thread to enter a photo, click on the A.jpg at top left, then be able to double click the image and select full size. I believe that option makes it fit the viewers screen no matter their resolution. Some forums have it defaulted so the image already shows and you don't even have to click on the A.jpg at top left.
Here you have to go to the advanced screen to do any of that and it is time wasted. It also makes you have to use the back button several times to get back to where you were in the thread listings.
Ih 490 Disk (A50514)
2017 FREIGHTLINER CASCADIA (A50854)
2017 FREIGHTLINER...
2004 INTERNATIONAL 4300 CARGO TRUCK (A50854)
2004 INTERNATIONAL...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2021 Doyle 8 Ton Trailer Tender (A51039)
2021 Doyle 8 Ton...
