I'm upgrading mt B3200 to an L4400
   / I'm upgrading mt B3200 to an L4400
Very wise move, especially to figure it out and act on it so soon. I have owned other tractors so the L4300 I have (same as L4400) was a quick choice for me.
It is one sweet and powerful tractor. Price is right, power great and user friendly.
You can also add draft control--I did--and grade with a rock rake like a pro. It uses so little fuel I thoughy the gauge was broken.
Ford skid steer weights fit the front weight bracket if it matters and the plug-in for the work light is under the rear fenders.
Might be one under the seat as well. Good call and congrats. Eagerly awaiting photos.
Good info, thanks:thumbsup:
   / I'm upgrading mt B3200 to an L4400 #12
dex3361 - Is your 3PH jerky? If so is it a problem?
The 3ph on mine is not jerky. You can slow down the movement of the 3ph by the speed control valve. It is a knob located below and in front of the seat. :thumbsup:
Mine is jerky when you try and lift the implement slow. If I just yank the lift handle all the way up in one motion it doesn't jerk.
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
International 1420 Combine (A50514)
International 1420...
UNUSED AGT QNT50R EXCAVATOR (A51243)
UNUSED AGT QNT50R...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52128)
NEW 2024 LOAD...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2014 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2014 GENIE...
