I'm missing something: Front-end 4-wd
   / I'm missing something: Front-end 4-wd #1
Raul-02
Veteran Member
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
Kioti DK47 se hst
I've noticed a couple of things. When I have it on solid pavement 4-wd is a definite no no. So I take it out of 4-wd before hitting pavement.
But in the muck with 4-wd engaged, lately I observed that the front wheels can spin freely and appear not to be driven.
For example I've had one wheel in slippery much or in the air and it doesn't spin with the driven wheels.
So concerned that maybe I broke sumpin', I asked my dealer. He's real straight shooter. I have every reason to trust him and none to not trust.
He told me that was normal.
But I''d been on pavement in 4-WD when I was new to the tractor and recall the chinky thumping behavior of the tractor on smpth pavement in a turn and at the time recognized that that unpleasant condition was because I stupidly had it in 4-WD.
So I asked Kioti this morning.
They got back right way with this
"Thank you for contacting KIOTI. To answer your question, the DK’s front differential is open with the power being distributed to the wheel with the least resistance."
OK
A) That doesn't jibe with my experience of seeing the wheel in the air not spinning.
and
B) That sort of makes no sense at all shouldn't it be the wheel with the most resistance? Did they just build a crap Automotive style limited slip in the front end?
and
C) DAMN~!! I'd have expected a lock up differential. Is there an after market item for that?
Don't bother telling me about the warranty. I already know. Ya can if ya want, I can't stop ya. But I already know.
   / I'm missing something: Front-end 4-wd #2
A) the tire in the air should have been spinning
B) You don't even have a limited slip differential it is a plain open diff.
C) I haven't heard of aftermarket diffs for tractors, I would expect you could get one remachined to fit if you spend enough money.
As far as finding out if it's broke get jack up one wheel and try and rotate it in 2wd, then engage 4wd and try.
should rotate in 2wd and driveshaft to the front should turn.
Now lower that wheel and do the same with the other side.
if that all checks out, lift both tires in the air and in 4wd try to rotate one tire the other should rotate the opposite direction.
Very few under 100 hp tractors have limited slip front axles or front diff locks.
Of course if you are carefull to only use 4wd when the conditions allow slippage you could do a Lincoln lock to the differential.
   / I'm missing something: Front-end 4-wd #3
...example I've had one wheel in slippery much or in the air and it doesn't spin with the driven wheels....
Could be that the wheel that's in the muck is being pushed (rolled) through the mud thus making it even less resistance than the tire in the air.
   / I'm missing something: Front-end 4-wd #4
Both my Kubota M9's have open front diff's with manual lockup just like the back. I rarely use it however. You lock the front and the back, straight line movement is the only movement you can make....lol I use the rear lock infrequently, mostly when plowing snow but with the expensive chains I bought that you suggested, I don't have to do that anymore...lol
I do know that Kubota quit offering that on later models (after 2004), I believe because of the excessive strain you can put on the front differential if locked in a high traction situation. I see they now have an 'on demand system' instead of manual lockup via cable linkage.
   / I'm missing something: Front-end 4-wd #5
Unless one rear tire is spinning the front would only spin at the rate of the rear. Suspect tire still would turn though if the tractor is moving.
Yes on diff lock makes fence lines get close quick since you can't turn..
   / I'm missing something: Front-end 4-wd #6
Kioti DK47 se hst
OK
and
and
B:.. It's not limited slip (clutch pack). it's an open differential far as I know at least (see Lou's comment and mine)...
C...No aftermarket locker available and an automotive locker won't fit anyway, not enough room in the case.
Perform the Lou test, you may have internal issues and if you do, there will be metal in the fluid. I suggest draining it and having a look-see.
Of course saying that, I'd never have any tractor with HST. They don't fit into my farming scheme of things. Way too much parasitic power loss.
   / I'm missing something: Front-end 4-wd #7
Your tractor should have a manual rear diff lock. Usually its a pedal you step on. Apply it when the wheels are not moving and ease on the power gradually until you feel it slide into mesh.
When a rear tire is spinning you can apply the brake for that wheel after unlocking the brake pedals so they can move independently. That's also good for making tight turns.
   / I'm missing something: Front-end 4-wd #8
The one big no no when engaging the rear diff lock is, never engage it with either wheel spinning, always cease movement. Reason is, if you engage it with the heel spinning, you will destroy the locking pins.
   / I'm missing something: Front-end 4-wd #9
My 80’s Kubota M5030 had a wonderful Detroit style locker front axle. No clutches. Seamless worked well supplying torque to the wheel with most traction. Yes it was big and heavy. Made a big difference on hillside work. My newer tractors don’t have this feature.
First I've heard that.
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
CAT D16 LGB (A50322)
Onsite begins 8:30am / Online begins 9:30am (A50121)
Onsite begins...
