Tractor Sizing I'm looking to buy a tractor to use primarily as an offroad forklift.
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #11
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #12
Another consideration - how high are you going to be lifting that 2500# load. FEL capacities decrease rapidly with height.
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #13
Suggestion - buy an off-road fork lift or tele-handler.
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #14
You壇 be way better off with a real off road forklift. It would take a pretty good size tractor to handle 2500 pounds. Like the biggest of the L series might but that痴 MX territory.
MX with just forks might lift 2,500 if you could keep the weight against the pins but I wouldn't want to drive it anywhere with a load like that, especially off road.
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #15
The other option depending on how high it needs to be lifted but a 3pt set of forks will have a lot more capacity with a lot more safety in a smaller machine. Still gonna need a good size machine though.
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #16
If the main use is as a forklift you need a forklift,
it forks are a secondary consideration but a major issue get a 3 point fork.
Build;
or buy;
3-Point Attachments | Westendorf
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #17
Hey guys. I've been wanting to buy a tractor and put a fork attachment on the front of it. I went to the kubota dealer and the sales guy basically all his tractors he had on the lot would only lift 1000 pounds max. I think his were all the 2000 series tractors. So what size tractor do I need to be able to lift 2500 pounds with a fork lift attachment? I'm not looking for a brand new tractor since they have the tier 4 emissions junk on them, but I am a fan of kubota. Maybe even an old ford tractor, it could be 20-25 years old for all I care just as long as it's in good shape.
Offroad forklifts are expensive even used.
WHAT are you looking to lift? How high? How often? Do you need to shift things in the same area, or do you need to carry them some distance? If so, over what kind of ground?
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #18
WHY?
It would help if you told us your applications.
For example I needed a machine I could take into the woods, brush cut, and lift a 1 ton log onto my sawmill. I got my M4700. If I had needed JUST to lift a 1 ton log I would have gotten a forklift.
Also be aware that older Kubota's are more lightly built compared to other brands in the same hp range.
   / I'm looking to buy a tractor to use primarily as an offroad forklift. #19
Club Car Electric Cart (A55758)
Club Car Electric...
2011 Isuzu NPR 14FT Box Truck (A56858)
2011 Isuzu NPR...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
Rooster Wooden Statue (A55853)
Rooster Wooden...
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
