Im having loads of troubles with attachments
   / Im having loads of troubles with attachments #11
EquipmentJunkie said:
Sounds like you are beginning to learn about the "pucker" factor.
You got that right! My "pucker" came when both rear tires lifted off the ground while loading the fel going down a 30 degree slope. WOW! What a feeling!
Oh..by the way, I always block the rear of the backhoe, between the stabilizers, up about 8 inches off the ground when I take it off. Big help when re-mounting!
   / Im having loads of troubles with attachments #12
I dug up about 20' of my lawn the 1st time I attempted to hook up my fel.. :(
Wouldn't have been so bad if the neighbors weren't supervising.
I'm sure they thought "look at the idiot pushing that front end loader around the yard" ...
   / Im having loads of troubles with attachments #13
Gunmaker,
Can you explain a little further about where you put the 8" blocks? Do they go under the stabilizer feet, the center, or both?
   / Im having loads of troubles with attachments #14
I put them in the center, underneath and between the lowest hinge points of the stabilizers. There is a small flat area on the bottom of the backhoe, almost directly under controls. It is about 16" by 12" and I found that I can block up the bh there, and it is very stable. I do leave my stabilizers extended.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A55301)
2023 NEW HOLLAND...
6' 3pt. Cultipacker (A50775)
6' 3pt...
2019 Cat D6 Dozer (RIDE AND DRIVE) (NEXT GEN) (A50775)
2019 Cat D6 Dozer...
US ARMY PORTABLE DIESELGENERATOR (A51406)
US ARMY PORTABLE...
2015 Ford F-550 4x4 ETI 37ft Bucket Truck (A55788)
2015 Ford F-550...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55302)
2025 Wacker Neuson...
