I'm glad everything is not built like my 4110
   / I'm glad everything is not built like my 4110 #41
Re: I\'m glad everything is not built like my 4110
I bought a used 4110 FEL which now has 1310 hours and the headlight switch work fine and is sturdy, and all lights work. The previous owner only used it to "pull logs from the woods" and so never used the PTO, which apparently has a stuck solenoid. The dealer had no service record on it and it appears the previous owner did not change fluids or do any service. However, it's running great except for the PTO which I haven't had a chance to check into yet. Overall, it is built very solidly. My only complaint so far is that the fuel filter is hard to get to with a FEL. I wish everything was built like my 4110, in particular cars.
   / I'm glad everything is not built like my 4110 #42
   / I'm glad everything is not built like my 4110 #43
There is a minor problem with the solenoid which engages the PTO, to sum it up it gets "DIRTY", and sometime needs to get cleaned and lubricated, it has happened once since I bought my 2002 Mahindre 4110 , and my son cleaned and lubricated it, nothing major. I use my pto often, and maybe thats why it rarely gets "DIRTY". I also have included this "CLEANING and LUBE" into my 100hr maintenance routine. Here is the fix I found on TBN
</font>(
[/quPoboy
Reged: 01/09/04
Loc: North Georgia
Re: 4110 PTO problems
#484761 - 08/23/04 02:13 PM Edit Reply Quote
The problem most of the time is not the solenoid itself but the spool valve it works when voltage is applied. The end of the spool is completly open on the end so grit can get inside causing the valve not to open. If your pto does not operate you can get underneath the tractor with it not running of course and simply push in the valve with a small nail or ball point pen. The valve is easy to locate if you look under the right side floor panel you will see a valve block with hydralic lines connected to it , to the rear you will see the solenoid which has two wires attached to it ther will be a plastic nut holding it in place in the center of this nut you can see a steel valve end approx. 3/16 of an inch in diameter. simply push in on this valve a few times and the pto should start working when you get back on the tractor. It seems to help if you spray a little wd-40 on the exposed area. This problem seems to happen on tractors that are not used for extended periods of time.
ote]
Here is another link http://www.tractorbynet.com/forums/remlinker.php?Cat=0&Entry=29889&F_Board=mahindra&Thread=693676&Main=688713 to a thread about this problem, with the Mahindra USA solution .
Buck
   / I'm glad everything is not built like my 4110 #44
</font>(
[/quPoboy
Reged: 01/09/04
Loc: North Georgia
ote]
Buck
   / I'm glad everything is not built like my 4110 #45
It's been my experience that you can have two identical machines, abuse the heck out of one with no problems, and baby the identical one and have problems with it.
   / I'm glad everything is not built like my 4110 #46
   / I'm glad everything is not built like my 4110 #47
Quote :
........................... I hope you don't take this the wrong way, but i joined this forum to get useful information..............
murray,
kenb's post is exactly that. Useful info, indeed. For the people who may consider this brand. /forums/images/graemlins/wink.gif
   / I'm glad everything is not built like my 4110 #48
Quote :
murray,
   / I'm glad everything is not built like my 4110 #49
We need less people posting without their profile filled out! It only suggests trolls.
Just finished cutting raking and rolling about rolls of hay with my Mahindra.
Happier everyday! 440 hours and still getting along!
   / I'm glad everything is not built like my 4110 #50
16ft Trailer T/A Equipment Trailer (A50322)
16ft Trailer T/A...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
7046 (A50322)
7046 (A50322)
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
