I'm an idiot
/ I'm an idiot #41
Re: I\'m an idiot
The dealer left a Toro ZTR at my house for demo. I came home from work, made a couple of laps around the front yard and decided to try my skills by trimming up to a flower bed. There was a slight downhill slope and my reflexes did all the wrong things. I ended up running over the top of a 12" stone wall and taking a chunk out of the granite cap and then cutting a big forsythia bush down. It destroyed both blades and scared the you-what out of me. I HAD to tell the dealer. He was gracious enough to pick it up and leave a different model. I ended up buying the original, but now whenever I go into the dealer, they manage to ask if I've run over any stone walls lately./w3tcompact/icons/blush.gif/w3tcompact/icons/blush.gif
/ I'm an idiot #42
Re: I\'m an idiot
I chopped off a PVC check point for the septic with my brush hog. At least now it's capped at groud level until the next time I run it over. Had I not let the weeds, grass, etc get so tall I might not have had the problem./w3tcompact/icons/grin.gif
/ I'm an idiot #43
Re: I\'m an idiot
WHen i was 13 dad told me i was old enought to start to operate construction equipment by myself well one day hed brought home a 580 Case backhoe from work. He had some little something to do and he told me i was gonna start on it. Well he put me to working down a row of old plum trees and at the end was our almost new cable dish that quit working so when i backed out i turned opposite of the sattelite forgetting that i still had the hoe behind me. What was fun was the time trying to straighten it.
Another time was i had welded a new bracket to my trailer when i was 18. I was taking it to a job and when i got the i had my ground clamp and ten feet of ground cable draggin behind me.
/ I'm an idiot #44
Re: I\'m an idiot
Speaking of dragging things, I actually saw a guy pull away from a filling station with the nozzle still in his fill pipe. I was amazed to see the entire pump drag behind him. The good news was there was no ensuing fire.
/ I'm an idiot #45
Re: I\'m an idiot
That's why the powers that be require breakaway connectors in the hoses now.
/ I'm an idiot #46
Re: I\'m an idiot
Ok, so this is not a CUT pic, but it's definitely a "I am an idiot pic"
That's me with the cup of coffee the morning after. My good friend Gary has come over to add moral support.
Even with the weekend rental of a Case 580 TLB to dig her out, still had to chain crossties to the tracks to get free from the mud's grip.
Dave Perry aka karma-kanic
/ I'm an idiot
Re: I\'m an idiot
<font color=blue>That's me with the cup of coffee the morning after. My good friend Gary has come over to add moral support.</font color=blue>
I'm surprised you didn't need one of those big Army helicopters to pull you out of that one!! /w3tcompact/icons/laugh.gif
/ I'm an idiot #48
Re: I\'m an idiot
The stuck dozer brings back a memory.. Back in 69 at the experienced age of 18 I took a short cut to the helo pad in Nam with a dozer. Went too close to the river's edge and down she went. Problem is the river is controlled by the tide in the Delta and as the water came up in the evening it just kept going deeper and deeper. That is where I learned about the suction water and sand can have on something stuck. They got it out with a tank retreiver as the Chief pointed out to me the stenciling on the side of the dozer that said "this equipment cost: $$$$.00." About a month later a new kid did the same thing only it was softer sand this time. That time I was able to act more experienced and say: "you shouldn't have gone that way"......... Tom
/ I'm an idiot
Re: I\'m an idiot
<font color=blue>They got it out with a tank retreiver...</font color=blue>
What's a tank retreiver? Is that the big helicopter?
/ I'm an idiot #50
Re: I\'m an idiot
<font color=blue>What's a tank retreiver?</font color=blue>
Here's a <A target="_blank" HREF=http://www.usmctanker.com/lemon/lemon1.htm>link</A> to a tank retriever in action.
<font color=blue>Is that the big helicopter? </font color=blue>
I'm not sure I'd want to be in a helicopter, no matter how big it was, as it strained to both lift a tank and break the suction of the surrounding mud. /w3tcompact/icons/laugh.gif
The tank retrievers I've heard of are typically like the ones in the aforementioned link. Usually they're used to retrieve damaged tanks from a battlefield, pull them to a safe area where they can be repaired. And, as has been mentioned, pull stuck tanks or bulldozers. /w3tcompact/icons/smile.gif
/ I'm an idiot
Re: I\'m an idiot
<font color=blue>The tank retrievers I've heard of are typically like the ones in the aforementioned link. Usually they're used to retrieve damaged tanks from a battlefield, pull them to a safe area where they can be repaired. And, as has been mentioned, pull stuck tanks or bulldozers. </font color=blue>
Wow.. that's a serious looking piece of equipment. I wonder if I could get one as military surplus? /w3tcompact/icons/wink.gif I'm sure it could get my JD4300 out of about any mess I could get it into! They probably go for millions, though.. and a little more if you want the CD player. /w3tcompact/icons/laugh.gif
/ I'm an idiot #52
Re: I\'m an idiot
Yes trev, But what would you use if you got the retriever stuck. I was caught out in the open when one the Sky Cranes came in to pick a damaged chopper. It managed to get sand into parts of my body I would never have dreamed I would have sand. I was definately imobilized during the incident. Afterwards, couldn't even pull the bolt back on my weapon without breakdown..... Tom
/ I'm an idiot #53
Re: I\'m an idiot
Were the Sky Cranes used to retrieve tanks, whether they were stuck or not?
/ I'm an idiot #54
Re: I\'m an idiot
I never saw a chooper pick up a tank. It is amazing what they can pick though. I was amazed that this big thing with rotor blades that kind of drooped when setting on the pad would not come apart lifting a load. And, that is why "I are not an Ingineer". When they get a load the rotors slap the air so hard the "bang bang bang" just keeps getting louder. Truely amazing piece of equipment..
/ I'm an idiot #55
Re: I\'m an idiot
I never have a problem with rear attachments-I nail everthing with the FEL instead...
/ I'm an idiot #56
Re: I\'m an idiot
<font color=blue>But what would you use if you got the retriever stuck.</font color=blue>
As a former crew member on an <A target="_blank" HREF=http://www.soft.net.uk/entrinet/armour9.htm>M88</A> recovery vehicle who got one stuck over the tracks in mud, I feel qualified to answer that. You get two recovery vehicle, hump what seems like miles of cable from the main winch of all three vehicles, rig half a dozen snatch blocks and winch it out.
/ I'm an idiot #57
Re: I\'m an idiot
We all do things that we wish we hadn't done. I once backed over a brand new tool box and have done many other things. You're not an idiot you're HUMAN /w3tcompact/icons/smile.gif
/ I'm an idiot #58
Re: I\'m an idiot
Trev - I'm afraid I would have to agree with banjodj on this one. I have met a lot of idots in my life and you are simply not qualified to be one. First, you noticed right off that something wasn't right./w3tcompact/icons/hmm.gif Second you actually stopped to find out what it was./w3tcompact/icons/eyes.gif Third, and most important, you admitted what you had done to others in a public forum./w3tcompact/icons/crazy.gif Not one of these traits was exhibited by ANY of the idots I have met. Usually they actually try to convince me that what every screwy thing they did was intentional.Now of course banjobj has opened a new question, what is more dangerous an idiot or a human?./w3tcompact/icons/laugh.gif
/ I'm an idiot #59
Re: I\'m an idiot
Hawkflyer,
Is that like the difference between stupid and ignorant?
One is forever, the other can be cured. :)
Don
/ I'm an idiot #60
Re: I\'m an idiot
One of the best lines I've ever heard to describe someone who didn't seem to know anything nor have any interest in improving their situation was "Too dumb to listen and too stupid to learn."
1994 Chevrolet C70 Kodiak 18FT Box Truck (A61573)
1994 Chevrolet C70...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2018 Merlo TF30.9-115 (A64119)
2018 Merlo...
