IHC rear brake drum
   / IHC rear brake drum #1
Rowski
North Central Vermont, Jay Peak Area
2004 New Holland TN70DA with 32LC loader, 2000 New Holland 2120 with Curtis cab, 7309 loader
Is it possible to slip off the rear brake drum without removing the whole hub? I need to get in to look at a noise. I removed the split backing plate and can see (barely) a tin or very thin steel piece. Its round (around the hub), not a spring. I thinking its like a slinger or something similar.
Truck is an International S1754 9.0L, Spicer 5 speed, Spicer (I think) 2 speed axle, air brakes, Budd wheels.
Thanks!
   / IHC rear brake drum #2
No way to get it off the drum is bolted to the hub will have to pull it as a unit
So it basically works like a mid 80's Chevy K35. Remove duals, remove axle, remove hub nut and lock, slide off drum/hub assembly.... Just a whole lot heavier.
Is it possible for 2 people to remove the drum/hub assembly or should I use an engine crane or floor jack.
Thanks
   / IHC rear brake drum #4
If you remove the tires you should be able to remove it by hand with out a problem You could use a floor jack to
Thanks....
I did the job this afternoon in between other work at the shop. The road commisioner let me use the a 3/4 impact which made a big difference, my 1/2 impact wouldn't touch it even after breaking them loose with a bar and pipe. Other than being heavy it went well. I cleaned the budd nuts and lugs well and made sure the mating surface on the rims were clean too.
The part making the noise was some sort a shield that is/was bolted to the drum/hub. It was pretty mangled up but no damage to anything else. Pretty amazing how simple the brakes are, so little parts.
I love this truck!
Again thanks for your help.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
MCELROY COOL PACK 20 (A53843)
MCELROY COOL PACK...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
Ingersoll-Rand Winch (A53117)
Ingersoll-Rand...
2003 International 4300 Cab and Chassis Truck (A51692)
2003 International...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
