IH Sicklebar Mower Model No?
   / IH Sicklebar Mower Model No? #1
Glenn9643
New Hebron, MS
MF 1455v 4wd, 1040FEL
This old sicklebar mower is missing the pittman arm, blade bar, and probably other parts but I would like to identify the model number and see if I can get parts for it. It's got IH stamped all over the castings but no data plate. Any help will be appreciated.
Pic 2
Pic 3
Pic 4
Probably should have put this in "Vintage Tractors" but thought this would get more response.
   / IH Sicklebar Mower Model No? #5
I have a sickle bar mower that looks like the one you showed. I have never found any data plate. Theissens in Cedar Rapids, Iowa sells the blades already on the blade bar and Pittman arms. I've seen Pittman arms in Tractor Supply, but I don't recall seeing the blade bars. It's been awhile.
   / IH Sicklebar Mower Model No? #6
Glenn,
</font><font color="blue" class="small">( This old sicklebar mower is missing the pittman arm, blade bar, and probably other parts but I would like to identify the model number and see if I can get parts for it. )</font>
Tractor Supply should have the wood part of the pitman but you'll need to have the hardware for each end. They also list three different 7' sickles for IH mowers (identified by manufacturer's part numbers), along with sections, rock guards, and a metal swath board.
I suspect that your local Case/IH dealer might be able to get the parts you need, also.
You might also want to post a message on the implement alley forum at
Yesterday's Tractors.
Best,
Jim Fisher
   / IH Sicklebar Mower Model No? #7
The mower looks like either a McCormick No. 25-V or No. 27 semi mounted mower. I have the owner's manual for the No. 25-V and it look's very similar. The manuals for these mowers are always for sale on ebay.
Thanks for the help. I found some archived pictures of the 25V and 27V, and I think mine looks more like the 27V based on the holes in the pulley from the PTO shaft and the lower structure. I also located owners manuals at binderbooks.com that are reasonably priced. Don't know if they have a parts manual yet or not. I've read that IH doesn't supply parts for these anymore but haven't checked. Any ideas where one might find a pittman arm with the hardware on it?
   / IH Sicklebar Mower Model No? #9
That looks exactly like mine it's an IHC-25-V
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
Woods Brush Bull 7' 3 pt Mower (A50514)
Woods Brush Bull...
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
2007 JOHN DEERE 310SJ BACKHOE (A50458)
2007 JOHN DEERE...
International 806 2wd Tractor (A52128)
International 806...
