IH Cub radiator plug out - what to do before I reinstall?
   / IH Cub radiator plug out - what to do before I reinstall? #1
lhfarm
Central Indiana
NH TC40DA
Had a radiator leak in my Cub Lo-Boy. Couldn't remove the drain plug, so I took the radiator out and caught the antifreeze in a tub. Drained the bolster and filled the plug hole with PB Blaster. I only have a small propane torch, but it was enough heat to allow me to break the plug free. I was using vice grips and the plug is chewed up. So should I just buy a new plug and use Teflon tape or anti-seize on the threads? Or weld a nut to the stub of the plug?
I'd just like to do something that will prevent this happen again.
Thanks,
   / IH Cub radiator plug out - what to do before I reinstall? #2
I would install a new one and put never sieze on it.
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
KOMATSU PC138US-10 EXCAVATOR (A52709)
KOMATSU PC138US-10...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
