IH Cub radiator plug out - what to do before I reinstall?
   / IH Cub radiator plug out - what to do before I reinstall? #1
lhfarm
Central Indiana
NH TC40DA
Had a radiator leak in my Cub Lo-Boy. Couldn't remove the drain plug, so I took the radiator out and caught the antifreeze in a tub. Drained the bolster and filled the plug hole with PB Blaster. I only have a small propane torch, but it was enough heat to allow me to break the plug free. I was using vice grips and the plug is chewed up. So should I just buy a new plug and use Teflon tape or anti-seize on the threads? Or weld a nut to the stub of the plug?
I'd just like to do something that will prevent this happen again.
Thanks,
   / IH Cub radiator plug out - what to do before I reinstall? #2
I would install a new one and put never sieze on it.
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A58018)
2020 KENWORTH T680...
2003 Big Tex 10PI...
HUSQVARNA RIDING...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
