IH CUB Cadet 149 will not disengage front power take-off
   / IH CUB Cadet 149 will not disengage front power take-off #1
docrocky
NW Ohio and SE Michigan
Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
This front power takeoff operates the mower deck. No matter what I do with the lever or loosen the clutch lever, I can't get the clutch to disengage fron the drive shaft. The lever wear button was in fragments and i don't know where the pressure spring thrust button is located. do I have to remove the whole assembly of is there a possible quick fix, I have sprayed with penetrating oil, lightly tapped the mechanism as well as stried to pry the clutch from the "cookie cutter " drive attached to the main drive shaft.
Where do I go from here? No local existing cub cadet dealers available. Only the big box stores now a days.
Thanks
Oh, no help from " only cub cadets forum"
   / IH CUB Cadet 149 will not disengage front power take-off #2
The set screws are "double", you have to remove the first one to loosen the second.
And, yes, you need to take it completely out,, that will make it easy,,,,
Adams Tender / Magnolia Trailer (A55301)
Adams Tender /...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A55301)
3-Point Hitch Root...
2019 MACK ANTHEM AN64T  TANDEM AXLE SLEEPER (A56138)
2019 MACK ANTHEM...
Sweepster 60" Skidloader Bucket Broom (A50775)
Sweepster 60"...
American Flag Decorative Sign (A55758)
American Flag...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55788)
2015 Chevrolet...
