docrocky
- Joined
- Jul 18, 2011
- Messages
- 207
- Location
- NW Ohio and SE Michigan
- Tractor
- Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
This front power takeoff operates the mower deck. No matter what I do with the lever or loosen the clutch lever, I can't get the clutch to disengage fron the drive shaft. The lever wear button was in fragments and i don't know where the pressure spring thrust button is located. do I have to remove the whole assembly of is there a possible quick fix, I have sprayed with penetrating oil, lightly tapped the mechanism as well as stried to pry the clutch from the "cookie cutter " drive attached to the main drive shaft.
Where do I go from here? No local existing cub cadet dealers available. Only the big box stores now a days.
Oh, no help from " only cub cadets forum"
