IH B414 Water pump torque spec
   / IH B414 Water pump torque spec #1
coxsp
Kingston, Ontario
International Harvester B414
What's the torque spec on the water pump 3/8" stud bolt for B4141 diesel? I thought I saw it in the service manual a few years ago but can't find it now. Generic torque charts range from 20-70 ft/lb, depending on the grade of bolt. 23 ft/lbs doesn't seem to be enough, as it leaks coolant from the gasket, and I don't want to snap a stud off.
   / IH B414 Water pump torque spec #2
Go with grade 5 bolt specs (33 ft-lbe dry) .... If gasket leaks, try cleaning gasket surfaces (again) and maybe some aviation type (non-hardening) gasket sealer....
Dale
Thanks for your thoughts. I'd cleaned it up with steel wool and compressed air, and used Permatex ultra black for a gasket. It's been hovering around freezing and I thought temperature may have been a factor. I actually measured the bolt today and it's 7/16x14, putting it at 50ft/lb dry or 35ft/lb lubed according to my chart. Being a greasy old tractor, I split the difference at 40ft/lb. It has to set for 24 hours, so we'll see if it holds coolant tomorrow.
2019 CATERPILLAR 336GC EXCAVATOR (A52706)
2019 CATERPILLAR...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
Rooster Weathervane (A55758)
Rooster...
Wacker Neuson RTSC3 (A47477)
Wacker Neuson...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2000 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
2000 POLAR TANK...
