IH B414 Water pump torque spec
   / IH B414 Water pump torque spec #1
coxsp
Kingston, Ontario
International Harvester B414
What's the torque spec on the water pump 3/8" stud bolt for B4141 diesel? I thought I saw it in the service manual a few years ago but can't find it now. Generic torque charts range from 20-70 ft/lb, depending on the grade of bolt. 23 ft/lbs doesn't seem to be enough, as it leaks coolant from the gasket, and I don't want to snap a stud off.
   / IH B414 Water pump torque spec #2
Go with grade 5 bolt specs (33 ft-lbe dry) .... If gasket leaks, try cleaning gasket surfaces (again) and maybe some aviation type (non-hardening) gasket sealer....
Dale
Thanks for your thoughts. I'd cleaned it up with steel wool and compressed air, and used Permatex ultra black for a gasket. It's been hovering around freezing and I thought temperature may have been a factor. I actually measured the bolt today and it's 7/16x14, putting it at 50ft/lb dry or 35ft/lb lubed according to my chart. Being a greasy old tractor, I split the difference at 40ft/lb. It has to set for 24 hours, so we'll see if it holds coolant tomorrow.
2015 Ford F-450 Crew Cab Knapheide Service Truck (A55788)
2015 Ford F-450...
KUBOTA M7-132 (A53084)
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
UNUSED LANDHONOR LHR-EW20000 ELECTRIC WINCH (A54757)
UNUSED LANDHONOR...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55218)
2016 RAM 5500...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
