IH B414 Water pump torque spec
   / IH B414 Water pump torque spec #1
coxsp
Kingston, Ontario
International Harvester B414
What's the torque spec on the water pump 3/8" stud bolt for B4141 diesel? I thought I saw it in the service manual a few years ago but can't find it now. Generic torque charts range from 20-70 ft/lb, depending on the grade of bolt. 23 ft/lbs doesn't seem to be enough, as it leaks coolant from the gasket, and I don't want to snap a stud off.
   / IH B414 Water pump torque spec #2
Go with grade 5 bolt specs (33 ft-lbe dry) .... If gasket leaks, try cleaning gasket surfaces (again) and maybe some aviation type (non-hardening) gasket sealer....
Dale
Thanks for your thoughts. I'd cleaned it up with steel wool and compressed air, and used Permatex ultra black for a gasket. It's been hovering around freezing and I thought temperature may have been a factor. I actually measured the bolt today and it's 7/16x14, putting it at 50ft/lb dry or 35ft/lb lubed according to my chart. Being a greasy old tractor, I split the difference at 40ft/lb. It has to set for 24 hours, so we'll see if it holds coolant tomorrow.
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2014 Ford Explorer SUV (A53424)
2014 Ford Explorer...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2023 Ford F-150 4x4 Crew Cab Pickup Truck (A55788)
2023 Ford F-150...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
