IH B275 Diesel Tractor Hyd Selector Valve Oil leak
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #1
Trailblaser
Mallala 70km North of Adelaide South Australia
IH B275 Diesel Fordson Super Major MF1085
Hello All, while using my recently acquired IH B275 Diesel tractor on the weekend to do some mowing with the TPL Slasher that came with it, I noticed that when I raised the slasher there was oil leaking from the top of the selector valve, which is located under the seating position. When I lower the slasher into the working position the oil leak stops, I have had a look at the schematic diagram for the selector valve and read through the description of operation, and am having trouble working out where the oil could be leaking from, it looks like it could be from the main valve or the main valve assembly, I am wondering if anyone can help guide me to solve the problem??
Trailblaser
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #2
Go to Brand specific....Mc Cormick and look there for info
Hi DLTTrekkers, just had a quick look thru McCormick specific and couldnt find anything, are you referring to any specific posts??
Trailblaser
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #4
OK.....wil look in my book and take photos and upload
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #5
In the meentime you can take some photos of where the leak comes from . I will be back home in about 6 hours to send you some info from the book
   / IH B275 Diesel Tractor Hyd Selector Valve Oil leak #6
Hi DLTTrekkers, thanx for the photos, I will have a closer look , and take some photos myself of the offending (leaking) valve and try to post them tomorrow
Trailblaser
Hi again, here are some photos as discussed
B275 Selector Valve #9 September 2018.jpgB275 Selector Valve #16 September 2018.jpgB275 Selector Valve September 2018 resized.jpg
the first is the tractor , and the others show where the valve is leaking
does that help??
Trailblaser
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2016 HAMM HD+ 120I SMOOTH DOUBLE DRUM ROLLER (A51246)
2016 HAMM HD+ 120I...
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
