IH 706
   / IH 706 #1
jsberhow
Looking at using a IH706 to pull a 13' John Deer 110 Disk. Any thoughts on this? I think that this may be pushing the limits.
   / IH 706 #2
I pulled a John Deere 12 ft. AW disc for years with a 3020 JD (65 hp) with no problem at all. Ken Sweet
   / IH 706 #3
We used to pull a 10' with an old 60 JD and a 706 is way more tractor than that. It should pull that no problem.
Kim
   / IH 706 #4
I think the 706 is 70 hp at the drawbar ... depending on soil you should be good. You can always lift it out of the ground a little with the Hyd's if need be.
I pull 10' with 55 hp ... sometimes in light ground when the disc is going in past the center of the blades I have to bring it up some.
   / IH 706 #5
My gasser 706 has 65 engine HP. I believe the diesel has a couple more ponies. With the TA for the tough pulling spots you should be fine.
   / IH 706 #6
I use to pull a 12' international disc with my Ford 7710-II which is 86hp from the factory. It was actually turned up and was putting out 120hp. I farm heavier ground then most so it pulls harder then it should depending on ground conditions. If the ground was too wet you will struggle but if its not a power issue, its a traction issue. When the ground conditions are perfect I can pull that disc with my TN65. A 706 should have no trouble.
   / IH 706 #7
the JD 110 is a lighter disc and the 706 should be able to pull it!
2017 JOHN DEERE 350G LC EXCAVATOR (A52705)
2017 JOHN DEERE...
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2011 KENWORTH T800 (A53843)
2011 KENWORTH T800...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
