IH 595 tractor PTO problem
/ IH 595 tractor PTO problem #1
NelsonP
Case IH 595
After an hour or two PTO stops working if I put tractor in reverse it will work again for awhile then stop completely if I stop the tractor for four or five hours it repeats the same cycle. Also just lately the PTO keeps turning slowly when not engaged , any help would be appreciated, thanks.
/ IH 595 tractor PTO problem #2
This sounds awfully similar to how my Mahindra 3616 acted when/right before the one way pto clutch failed. The pto would stop under use at times, restart after a slight reverse. And the shaft would spun slowly but could be stopped by hand. I'm not sure of anything on your model. But now I'm going to look into it.
/ IH 595 tractor PTO problem #3
That series IH tractors had no one way clutch. Only a hydraulic clutch pack, which in this case I believe is suspect. Losing power to drive a load could be a low/insufficient pressure problem, but the creeping when turned off symptom is more likely a result of some mangled clutch drive discs. The drag between the clutch plates is overcoming the brake plate so the unit continues to turn. I see a clutch pack repair in your near future.
/ IH 595 tractor PTO problem #4
I looked into this tractor after my initial post. Noe I see that my post has no value.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
KBH Tender (A63688)
KBH Tender (A63688)
John Deere 6359DF (A64119)
John Deere 6359DF...
(2) UNUSED UNVERFERTH 8-10 WHEEL SPACERS (A64280)
(2) UNUSED...
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
