IH 585 brakes
   / IH 585 brakes #1
delchip
the foot brakes keep jamming on usually after about 5mins they jam if left for 5mins come off then jam again just gone out to use it brakes are on from the start any ideas
   / IH 585 brakes #2
Hmm, not sure, the main brakes are hydraulically actuated, they get topped up automatically from the oil sump for the transmission. Are all other hydraulic functions ok?
The parking brake is a mechanical brake, not sure if it is a band type or what, is worn out on all IH's I've ever used from being forgotten on.
   / IH 585 brakes #3
I've not seen this problem but it has to start at the control. The brakes themselves could not do this. Check at your actuator first.
   / IH 585 brakes #4
Was there a solution to this problem found. I have a 595 with almost the same problem,
   / IH 585 brakes #5
Check the drain on the reservoir on top of the master cylinders. If the drain line is kinked or plugged the brakes will engage.
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2015 CHEVROLET SILVERADO 2500 (INOPERABLE) (A58214)
2015 CHEVROLET...
LOT: (3) Sections of Steel Pallet Racking Welded Together: (1) 9' W x 9'H x 48" D, (1) 9' W x 7' ... (A59076)
LOT: (3) Sections...
John Deere 5103 (A53317)
John Deere 5103...
