IH 584 fuel starvation maybe?
   / IH 584 fuel starvation maybe? #1
badja
North Yorkshire, United Kingdom
MF35, Int 584
My 1979 IH 584 has started chugging and revving and it looks like it has a fuel starvation problem. I am going to replace the 2 fuel filters but is there a fuel/water separator in the fuel line? Anything else I need to look into, apart from plenty fuel.
   / IH 584 fuel starvation maybe? #2
Fuel filters first and while off make sure you have a good flow from the tank!
   / IH 584 fuel starvation maybe? #4
No they didn't here in the US.
How's this for a Newbi mistake.
Checked for fuel at fuel tank tap and nothing. Checked there was fuel in, removed tap, full of c**p.
Tractor working fine now but will still change filters.
Thanks for assistance
   / IH 584 fuel starvation maybe? #6
I own a 684 and had the same issue last week. I thought I had run out of fuel but there was a little in the tank. I found
the fitting with the shutoff valve clogged. I decided to drain tank, remove all tank fittings, clean them and clean the tank the
best I could. When i drained the tanks put a towel over a funnel in a clean jug to strain the filth. Amazing what has collected
in the tank. Now it runs fine. Probably something that needs done every couple of years. I will check the gasket on my
fuel cap to be sure it is good.
2003 KOBELCO SK235SRLC EXCAVATOR (A54607)
2003 KOBELCO...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
