IH 584 fuel starvation maybe?
   / IH 584 fuel starvation maybe? #1
badja
North Yorkshire, United Kingdom
MF35, Int 584
My 1979 IH 584 has started chugging and revving and it looks like it has a fuel starvation problem. I am going to replace the 2 fuel filters but is there a fuel/water separator in the fuel line? Anything else I need to look into, apart from plenty fuel.
   / IH 584 fuel starvation maybe? #2
Fuel filters first and while off make sure you have a good flow from the tank!
   / IH 584 fuel starvation maybe? #4
No they didn't here in the US.
How's this for a Newbi mistake.
Checked for fuel at fuel tank tap and nothing. Checked there was fuel in, removed tap, full of c**p.
Tractor working fine now but will still change filters.
Thanks for assistance
   / IH 584 fuel starvation maybe? #6
I own a 684 and had the same issue last week. I thought I had run out of fuel but there was a little in the tank. I found
the fitting with the shutoff valve clogged. I decided to drain tank, remove all tank fittings, clean them and clean the tank the
best I could. When i drained the tanks put a towel over a funnel in a clean jug to strain the filth. Amazing what has collected
in the tank. Now it runs fine. Probably something that needs done every couple of years. I will check the gasket on my
fuel cap to be sure it is good.
2014 CHEVROLET IMPALA 4DOOR SEDAN (A54313)
2014 CHEVROLET...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
