IH 460 Power Steering.
/ IH 460 Power Steering. #1
kbforester
Pembroke, ME
International 460 Utility
Already posted this in the repair forum, but I haven't gotten much response. Figured I'd try here!
The power steering gear assembly. These tractors are apparently notorious for steering problems. I got the tractor this summer, and it ran great except it was leaking hydraulic oil from the power steering gear assembly (I was going through more H Oil than gasoline!). But it actually WORKED just fine. Tore the tractor apart to get it off, and sent it to a local guy to overhaul. He said he couldn't find anyone who carried a needle bearing (#5 in the diagram). He packed it up and said it wouldn't leak at least.
Now that I have been able to test it, I discovered I don't have the full range of rotation in the steering wheel anymore. Basically, without adjustments, I can only make normal sharp right hand turns and just barely veer to the left. There is zero resistance issues, it just stops prematurely, and completely when I turn left.
My question is: Could this be the needle baring, or something completely different?
It doesn't sound like a bearing to me. Could it be a mis-calibrated gearing somewhere? Like, it was reassembled improperly so something bottoms or tops out too early. If you agree, does anyone want to take a stab at which one?
I don't want to ask the guy that rebuilt it, I don't trust him.
I think I can readjust everything (arms and tie-rods) to balance the steering so I can turn an equal amount in either direction, but its really not going to be enough to be useful. I had the wacky idea of extending the steering arms to get more tie-rod movement for what little rotation I have left. Not sure if that will be good enough.
Any thought would be much appreciated.
-KB
/ IH 460 Power Steering. #2
Is the steering valve a orbital valve? As in when you turn your wheels to the left and the wheels stop turning can you still turn the steering wheel to the left?
I can't turn the steering wheel any farther to the left. It just stops solid.
/ IH 460 Power Steering. #4
Hmm was the wheels centered and the steering wheel centered when you put it back on? I don't know my 460 and 560 very well only been around them a time or two I'm sure someone on here knows!
I think I understand your question.
Yes, it was, I've also tried to re-adjust, to see if I could distribute the error in both directions.... to see if its tolerable. Its not. I'm going to be using the tractor in my woodlot and maintaining a plantation, so tight corners are important. I use the foot breaks separately, but I can only skid so much when the fields are soft.
As a fellow 460 owner, I should also note this is a 460 utility. The 460s had a bunch of differnt steering setups.. and the farmalls were different still.
/ IH 460 Power Steering. #6
I suspect the control rack and the two sector gears were probably assembled incorrectly. You will need to remove the case housing #46 and both sector shafts, #37 and #40. Center the control rack #49, then install the shafts each in center of their respective tooth contact paterns. If there are no marks or stamped gear teeth to match, it may take a trial or two to get the position correct, but doesn't look too complicated. It appears the process could be done without removing the unit from the tractor
I think I got it near 100% now. Thanks for the help. Just a little more tinkering.
/ IH 460 Power Steering. #8
A old timer told me there’s a propositional valve in the steering box that messes up the power steering I have one that works like crap
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
6ft Metal Star (A65583)
6ft Metal Star...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
JMR TREE BOOM (A61572)
1987 Asphalt Tanker Trailer (A65563)
1987 Asphalt...
