Oil & Fuel IH 454 injector pump
/ IH 454 injector pump #1
MKS69
La Vernia, TX
I have an IH 454 with a Bosch injector pump. The pump is leaking from the top of the pump around the diamond shaped plate which I think is the advance housing plate. These are my questions.
1. Can I just replace the seal for that particular part, or is it a sign of a bigger problem.
2. If it's just that seal, is it something a novice mechanic can do.
3. What is the procedure for removing the pump and once it's replaced how do you prime it.
Thanks in advance for any helpful tips
/ IH 454 injector pump #2
Seen your post on the other forum, iwill get some info and reply to you on that forum ????
207277 (A52708)
207277 (A52708)
Adams Tilt Trailer (A63118)
Adams Tilt Trailer...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A63118)
2025 Wacker Neuson...
2019 John Deere 835R Gator (A63116)
2019 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Spray Daddy 400 Gallon 30 ft Sprayer (A64047)
Spray Daddy 400...
