IH 244 transmission problem
/ IH 244 transmission problem #1
clay11
I am having trouble with my tractor locking up in two gears. Any suggestions?
/ IH 244 transmission problem #2
When ever I have run across this it is because of excessive wear, usually on the bottom of the shifter. When it wears thinner it lets the first shift rail drop back into gear while going into the next gear. I have welded them back up and then ground back down to size.
If the detent balls are loose or missing it could cause a problem too.
My worst experience was with a VW offroad dune buggie. I was in the woods mowing down 1-2" trees making a trail. I had to stop and went to back up and the shift rail dropped back into first gear while the shifter went into neutral. I had to get a chain saw and cut it out and drive it back in first gear. It was an easy fix, I took out the trans fill plug and popped it back into neutral with a screwdriver.
UNUSED TAYLOR-WAY 5' BOX BLAD (A62130)
UNUSED TAYLOR-WAY...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2002 BMW 325Cic Convertible Coupe (A61569)
2002 BMW 325Cic...
2025 Hydraulic Brush Cutter Mini Skid Steer Attachment (A61567)
2025 Hydraulic...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
