IH 140 chokes down
   / IH 140 chokes down #1
w12kpm0w40
McColl, SC
1963 IH 140
:mad:
After teradown and replace 2x the carbeurator on 52-63 IH 140 w/ zenith carbeurator
The tractor cranks right up!
It runs wel. As soon as I engage pot, it stalls and will choke down unless I stop pto.
The tank has ben drained and is clean; the filter screen is clean, fuel is arriving to the neck of the carbeurator. Why does it stop/choke down when pto engaged??
My grass is growing by leaps and bounds.
Al
   / IH 140 chokes down #3
Have you tried adjusting the main jet..?? If I'm understanding right, this is a new, or rebuilt carb..??
Gently run the main jet screw in, until it bottoms out. Back out 1-1/2 turns, and see how it runs then. If somewhat better, but not to suit you, you can tweek it in or out from there to get the final adjustment.
   / IH 140 chokes down #5
w12kpm0w40 said:
thank you
Does it stall out only when you use the pto, or does it also stall when you drive it? Could be your pto is frozen up.
only stalls when pto runs cutting with bushhog after a short distance symptom is like choking down than torque from pto strain or lockup
   / IH 140 chokes down #7
After re-reading your original post, about the filter screen... Is that the one above the sediment bowl..?? If so, did you check the internal one in the carb.? Where the fuel line attaches to the carb., that el has a filter screen on it.
Sounds like lack of fuel, or you've got a vacuum leak.
Or, possibly the governor is not activating like it should, when under load asking for more fuel.
   / IH 140 chokes down #10
My fuel line is steel, but I suspect, it could happen with either. Good luck.i
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
